Quietest Cat Back for LS1 Camaro
setup for their SLP_D/D. All of the factory I-pipes are a
rough 3" diameter (though my CME I-pipe bulges out aft
of the front clamp, a bit). I'd float the idea in the parts
section, you never know.
Here is the motor specs for those interested.
new alum 4.125" bore LS7 block resleeved by R.E.D. (Steve Demirjin), billet main caps, ARP main studs, rebushed titanium LS7 rods, Katech A1 rod bolts, Autotec lightweight race pistons, Total seal Rings, Eagle 4.1" crank set up for wet sump factory style pump setup. 11.5:1 compression, WCCH LS7 heads, cleaned up ports, Brian Tooley racing springs/titanium retainers, new guides, s/s exh valves, titanium intake valves, performance VJ. LS7 intake, LS7 fuel rail, LS9 injectors, hydraulic roller cam (238/248 duration, .652" lift) spec'd for me by Brian Tooley. LS7 lifters, Brian Tooley pushrods, ARP head bolts, MLS gaskets, LS7 rocker arms with Comp Cams trunion bearing rebuild kit, Melling oil pump, billet Katech tchain.
It is an illusion that the car looks like it is about to fall off the lift.
