POTZ tb getting stuck at WOT...Advice
Check the cable while it is disconnected. It should move back and forth smooth. Have some one give you a hand. Disconnect it from the throttle body but leave it in the bracket and have someone push the pedal slowly than you pull it back. It should be smooth and easy.
I'm sure it's tough to eyeball but it might be going past 90* open. You can put some RTV or something on the throttle stop to limit it a little (basically undo what he milled off) and see if it still does it. If it does, it's something else. You need to use the process of elimination.
I'm not sure how I would install it? Sorry that I am stupid Could you show where in the pics that I supplied? You're speaking about the bump/throttle stop that was shaved off some?
Can you confirm that if the blade is going past 90 degrees that it typically would be causing the throttle to get stuck?
Maybe you could try putting a few layers of tape on the bump stop to make sure it can't go past 90* then see if you can get the throttle to stick. If it gets stuck you need to look for a different problem, if not then you need to look for a more permanent but similar solution.
Honestly you should probably just throw it in the trash and get a new aftermarket one. I know it will be tough to do but you'll be kicking yourself for not doing it if you end up wrecking the car.
In the end, the car is being stored this Winter as usual and if I cannot figure it out by Spring then I will get an aftermarket one when I cam it.
#32
Are you sure your gas pedal isn't getting stuck to the floor some how. Could be getting caught on something (floor mat)or the pedal pivot point is worn and binds up with a certain pressure. I could be wrong but I don't think its the TB.
#33
I've see it happen on a ported throttle I was cleaning. See if it sticks when you pull outward or push inward on the throttle cam. I bet that blade is just slightly off center. It doesn't take much.
