new intake on the block
Old Jan 28, 2015 | 01:39 AM
  #201
McNasty's Avatar
Anyone know why we haven't heard anything about the dorman intake that was ported/cleaned up or whatever?
Old Jan 28, 2015 | 02:38 PM
  #202
Fry_'s Avatar
Probably never dyno'd it and even if he did he probably doesn't have any before numbers to compare them to.
Old Jan 29, 2015 | 03:22 PM
  #203
jwf02ta's Avatar
Here for the resulst...I may jst buy one of these in the next week and test it out against my ls1intake on my bolt on ls1 build
Old Jan 29, 2015 | 03:37 PM
  #204
sawblade99Z's Avatar
Please do! There are a lot of us wondering how it stacks up to an OEM piece on a stock/bolt-on build.
Old Jan 29, 2015 | 05:34 PM
  #205
dreadpirateroberts's Avatar
it would certainly be nice if someone could test the untouched dorman vs stock ls1, but what we really could use is a test of ported dorman vs an ls6--especially on a fairly modded motor. i'm not sure who wants to try it, since it's not exactly a returnable item once you've taken a sanding bit to the insides. hopefully a reputable shop can step up to the plate.
Old Jan 30, 2015 | 01:57 PM
  #206
Fry_'s Avatar
Peak Speed Shop needs to port and test one of these. If they can prove gains of say 5-10 hp on a cam only car, and 10-15 hp on a mild heads and cam car I'd say they could sell ported ones for $500-600.
Old Feb 3, 2015 | 12:19 AM
  #207
2000z346's Avatar
I bought 1 ported the runners and opened up the 73mm TB opening to match my TB smoothed and painted. It looks like a real good piece after some easy cleanup. I replaced a ls1 intake with it and u can feel a small difference jus driving the car. Won't have any dyno numbers until the weather warms up.
Old Feb 3, 2015 | 01:40 AM
  #208
ULTIMATEORANGESS's Avatar
nice job. it looks great.
Old Feb 4, 2015 | 02:18 PM
  #209
Well I caved and ordered one from parts geek. $294 shipped after the $15 dollar off code. They had 4 more in stock. Crossing my fingers someone posts up some favorable results with it.
Old Feb 5, 2015 | 06:40 PM
  #210
2000z346's Avatar
Thanks ultimateorangeSS. As far as performance numbers the car does feel a lot stronger than with the ls1 intake. It's untuned but I'd say it would hafta be 15hp or so to even be able to feel it. The ls1 intake was possibly holding the car back as well it's got a ported TB comp .610- 240@.050 cam longtubes 3" exhaust, FTP lid. About all the bolt ons.
Old Feb 13, 2015 | 09:15 AM
  #211
ATXSS's Avatar
Please do keep us in the loop on your results sawblade99Z. Been watching this thread for a while with my finger on the trigger but wont pull it until i hear good results from more than one person. Porting these things sound pretty easy if you've got some dremel skills, true?
Old Feb 13, 2015 | 11:22 AM
  #212
I posted up in the other thread and gave my initial thoughts on it. Basically I sanded the outside down and started working on the tb opening last night. I think it can be taken out to 78 mm without screwing up the gasket area. Then I'll be using a fast 90 porting write up in here for reference to work on what I can reach in each runner. I've got the Dremel to do so, but I'll need a longer sanding roll and probably an extension to reach all the way to the end of the wedge. Just need that and a steady hand. From what I understand keeping the wall straight is the hardest part. It'll be going on a heads/cam lq9 so we'll definitely see how it performs lol won't have any before/after numbers though.
Old Feb 17, 2015 | 10:08 PM
  #213
Proudsuperior's Avatar
Subscribed.
Old Feb 18, 2015 | 12:35 PM
  #214
McNasty's Avatar
If someone would do a test for stock ls1 intake vs the dorman vs the ls6 all untouched, then the ls6 and dorman both ported, I'd be so happy.
Old Feb 21, 2015 | 10:15 AM
  #215
mikesimpalass's Avatar
Default Ls2 intake
Does anyone know when dorman will start selling there ls2 replacement manifold? I saw a post from december that said the ls2 version should be available in two months
Old Feb 24, 2015 | 07:02 PM
  #216
Carguy8888's Avatar
Wow, in for the info.
Old Feb 24, 2015 | 07:06 PM
  #217
Those of you looking to see more pics check out the Dorman thread. I've finished the tb inlet on mine and got the outside sanded for paint. Will be starting on the bottom shell as soon as I get the proper attachments.
Old Feb 24, 2015 | 07:10 PM
  #218
Smile
before and after numbers if possible please.
Old Apr 3, 2015 | 06:57 PM
  #219
Brett H's Avatar
I am subscribing for the dyno results.
For those that currently have one, does it look like the Dorman can be modified to accommodate the EGR tube for those of us that need to pass visual emissions testing?
Old Apr 3, 2015 | 11:13 PM
  #220
The Dorman already has the EGR port, along with a cap for it. I'm not going to be using mine on this build, but I willl for sure use it on my next more budget minded build.
