water pump interchange
Old Nov 30, 2014 | 06:42 PM
busha61067's Avatar
Default water pump interchange
I have a 03 lq4 block going in a 2000 Camaro with and will be putting 2000 ls1 car accessories on it. what water pump do I need to go with. part numbers would be nice Thanks!!!
Old Dec 1, 2014 | 07:22 AM
garys 68's Avatar
just get a 00 Camaro pump.
Old Dec 1, 2014 | 10:17 AM
ChevyOwner's Avatar
What car accessories? Are they from a Corvette, or F-Body? If I understand correctly there is a newer style pump that should work with both, but I think it needs the newer style thermostat.
PS
If someone has measurements for the Camaro accessories that show where the belt sits on the water pump pulley in relation to the block I will be glad to measure the water pump I have.
Old Dec 7, 2014 | 02:24 AM
ls1 1990 VN's Avatar
Just get the GTO LS2 pump & thermostat. If you at anytime wish to upgrade to a Fast 102 intake/102tb you will have no fitment issues, plus have a separate thermostat housing unlike the LS1
Old Dec 14, 2014 | 10:40 PM
busha61067's Avatar
will the ls2 pump line up with my accessories from a 2000 z28
Old Dec 14, 2014 | 11:51 PM
YES it will
Old Dec 15, 2014 | 06:25 AM
garys 68's Avatar
Yes for a GTO.
No for a vette.
Old Dec 15, 2014 | 11:39 PM
Originally Posted by garys 68
Yes for a GTO.
No for a vette.
My engines a C5 & yes it does
Old Dec 16, 2014 | 05:36 AM
garys 68's Avatar
He's running an f body accessory drive.
As far as I know, the later LS2 pumps only had the narrow pulley.
Link to photos:
http://www.nookandtranny.com/Info_LSx.php#LSWaterPump
Old Dec 17, 2014 | 12:15 AM
Link to photos:
Your own link says this:
The Corvette, Camaro, Firebird and GTO all share the same water pump, even though they use different depth balancers. The reason the water pumps are interchangeable is that the water pump drive pulley is twice as wide as the other platforms, allowing the belt to ride in 2 different locations. Therefore, you can use either water pump with either platform, although you should check your clearance between your fans and/or radiator.
Old Dec 17, 2014 | 12:37 AM
garys 68's Avatar
Not to nitpick, but you omitted the last line:
"04 and later model Corvette platforms use a water pump that has the pulley only as wide as the belt."
An LS2 will be 04 and later, so the vette LS2 pump wont work. But I think the OP can tell by the pics which his is.
And of course we could both be wrong of it's off a Trailblazer or SSR.
Old Dec 17, 2014 | 03:32 PM
WEIGHTMAN's Avatar
does it matter if its car or truck ls2 because a ls2 truck crank pullies and car cranks are diffirent
Old Dec 17, 2014 | 04:40 PM
garys 68's Avatar
lol, here we go again...
There are 3 offsets for belt routing:
Corvette, CTS-V (closest)
98-02 F body, GTO (3/4" out)
L99 10+ f body, Truck (1 1/2" out)
I'm probably forgetting some.
But as far as I know, all LS2 vettes had a pulley that would only engage the vette configuration.
As was pointed out, earlier LS1 pumps on vettes and aftermarket had a wide pulley that fit GTO/F body/vette/CTS-V.
The LS2 pulleys on a trailblazer SS and SSR had the truck offset and would not work with the vette/CTS-V or f body/GTO offset. Double check me on this, pics on Rockauto website.
Now all will bolt up to any block, but you need to take in account the tensioner offset and tensioner used.....
Wanna get more complicated, try adding spacers and figuring tensioner offset. Weirder yet, try swapping pulleys (pic below of truck pulley on f body LS1 pump.
BTW, I see our friend is from down under. I wont even speculate on the Holdens or Utes....
Old Dec 17, 2014 | 08:15 PM
omc8's Avatar
Not trying steal this thread but , but have a question . I have a 08 4.8 LY2 and I want to keep the truck accessories but I need more clearance between the water pump and radiator. The pulley is the big bell style with the long threaded snout for mechanical fan to screw on. Is there a truck style water pump that has the a flatter thin bell without the snout. Something like the bell on the Corvette 04 and later water pump .
Old Dec 18, 2014 | 12:22 AM
Are you really this O4 Vette & later model Vettes is what the article is referring too.
God damn! The 04/06 GTO LS2 pump god damn fits OK!
OP is using F Body LS1 accessories
Old Dec 18, 2014 | 01:34 AM
garys 68's Avatar
lol, I honestly have no idea what you're talking about any more/
The OP has f body accessories.
He also has an LS2 pump;
It the pump came off a GTO, it will work.
If the pump came off a vette/CTS-V/truck it wont.
I hope that translates well
Old Dec 18, 2014 | 01:58 AM
garys 68's Avatar
I've had several truck pumps, they're all pretty much the same with the threaded snout.
The 2010+ camaro L99 pump is spaced farther out to clear the VVT timing cover and should line up with the truck accessories. Although I think they simply use the same accessories on the Camaro LS3 and L99. The pulley doesn't have the fan threads, so might be slightly shorter. A trip to Autozone to compare the two should tell you pretty quick.
It does have the front facing water inlet, but that can be cut shorter.
Old Dec 18, 2014 | 10:26 AM
Fullen's Avatar
At the end of the day...it's easier to find a water pump from someone parting out a '00 camaro. If others come up...you know what fits, but use whatever you find that's cheaper.
Old Dec 18, 2014 | 10:44 AM
ChevyOwner's Avatar
Actually the OP said the he has a LQ4, 2000 Camaro, and LS1 car accessories. He does not say the the accessory system is form the Camaro. For all we know the Camaro is a rolling chassis the OP is putting an engine in to drive it.
Old Dec 18, 2014 | 04:25 PM
omc8's Avatar
Thanks man , I will try that !
