which heads for ms4
Old Jan 3, 2015 | 05:44 PM
xdanny510x's Avatar
Default which heads for ms4
Im lookin for heads for a ms4 cammed z28 ..backed by th400 with a 4400 stall. 12bolt rear end . full bolt ons. Ls6intake. Im debating between the prc as cast 225cc heads or the prc 6.0 stage 1 heads .. Which ones would suit better
Old Jan 3, 2015 | 05:51 PM
high n dry's Avatar
What about the trick flow 255?
Old Jan 3, 2015 | 06:04 PM
xdanny510x's Avatar
Lookin for a budget type head jist to run for a short period of time while my 408 gets rebuilt.!
Old Jan 3, 2015 | 07:39 PM
Tuskyz28's Avatar
I'll call advanced inductions and talk things over with Phil. He can even make a set of 241 heads badass. Ask him about his high compression program for a 241 head.....
Old Jan 3, 2015 | 09:24 PM
HCI2000SS's Avatar
Why just those two heads only? I'm just curious
Old Jan 4, 2015 | 11:51 AM
xdanny510x's Avatar
Just lookin for a quick budget head.. And i saw that those clear the ms4
Old Jan 5, 2015 | 12:22 PM
xdanny510x's Avatar
Ttt maybe tsp can chime in
Old Jan 5, 2015 | 12:45 PM
Rise of the Phoenix's Avatar
Those wont' work on a 346ci. Of the choices you posted, I'd opt for the PRC 225cc as cast heads.
Old Jan 5, 2015 | 04:27 PM
VandykeT/A's Avatar
Not the 317s. I'd do the 225's but if you don't plan on leaving this set up I'd find some 243's and hand port them if you have alot of free time. It'll be tons cheaper.
Old Jan 6, 2015 | 04:10 PM
xdanny510x's Avatar
Im just lookin for a head to use while i rebuild my 408 and so i wont be bored without my toy lol
Old Jan 6, 2015 | 04:25 PM
Then buy a set of heads that you can use on both setups. Possibly wait for Tony Mamos new Mamo Motorsports 220cc heads.
Old Jan 6, 2015 | 05:18 PM
xdanny510x's Avatar
I got the ls3 heads on my 408 lol
Old Jan 6, 2015 | 06:03 PM
xdanny510x's Avatar
Wait lol i just did some researchin and totally left the tfs out of the question lol.. I remember back in the day they used to be alot of $$$ they run around the same as the prc lol thats why i didnt pay attention to them.. So i retract my previous statements
Old Jan 6, 2015 | 06:07 PM
Yeah, 408ci is fine, but not a 346.
Old Jan 11, 2015 | 05:59 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Thanks for choosing TSP for your camshaft! We've done tons of dyno testing with the MS4 camshaft so I'm sure we can put together just the right package for you!
As most of you know the PRC 227 is the ultimate small bore LS cylinder head on the market. The as cast is a cast version of that head. While it flows just slightly less than the 227, it is still without a doubt light years ahead of ported stock castings.
You get altered valve angles, thicker decks, 6 bolts incase you upgrade in the future, 2.065/1.60 valves & we can mill to your camshaft. For example 60cc chambers & your ms4! We can even sell them to you without springs if you want to move over your prc springs from you current setup to save $$$$
Considering a ported 241 isn't even a fair comparison....
Hope this helps!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
