LQ4 oil pressure sender
I am hoping I can leave the stock sender in place and use a different location for another sender if one exists.
And I was wondering about the oil cooler location. I have the cap on it now that came with the holley pan. I guess I could drill and tap it pretty easily.
http://www.ls1howto.com/index.php?article=18
I pulled the intake on my truck to change the OPSU and:
I agree with Mr Bell...and, be sure and look at the knock sensors also.
I've never taken one apart that old...that didn't need at least one or both knock sensors from water intrusion...
If you're gonna install the OPSU back in the block behind the intake manifold, get the GM dealership professional version, GM number 1261664. It's more robust than the aftermaket ones. I used a aftermarket version and it went bad in three months.
