Stock C/B vs True duals
Old 01-25-2015, 02:40 PM
M-Z28's Avatar
Default Stock C/B vs True duals
I have a 1998 Z28 and I'm currently running stock catback with a Flow Master 80. I will be completing Full Bolt On's this spring (LT Headers, LS6 intake, EGR delete Etc.) I have the exhaust narrowed down to 2 options.
Headers will be Speed Engineering 1-7/8"
Option 1:
Ypipe (w hf cats),to 3-1/2" Electric Cut-Out to Factory C/B with Flow Master 80
Thoughts with this set up race ready. Quiet when needed
Option 2:
TSP true duals with Sweet thunders
Thoughts with this set up sounds great, but full race all the time.. Which doesn't bother me, but I read a lot of people say it gets old.
What would you do guys?
Old 01-25-2015, 02:47 PM
ULTIMATEORANGESS's Avatar
will this car be a DD?
Old 01-25-2015, 02:52 PM
M-Z28's Avatar
No it will not be a Daily Driver!!
Old 01-25-2015, 02:55 PM
in that case i wouldnt go with cats. TDs is something im considering later on as long as they dont bottom out so thats what id go with.
Old 01-25-2015, 03:15 PM
M-Z28's Avatar
Where I live I still have to pass emissions. Currently my bro has a y pipe with cats sitting around so if I went TD I would have to swap out once a year...
This might be another expense though due to I can't count on his y pipe to just be sitting around...
Old 01-25-2015, 03:20 PM
if youre worried about inspection i wouldnt have anything loud unless you know someone that can hook you up with a sticker.
Old 01-25-2015, 04:36 PM
M-Z28's Avatar
Passing inspection will not be an issue.... With a catted y-pipe. As for everyday driven not worried about it..
Old 01-25-2015, 06:49 PM
tnmotown's Avatar
Like others have already mentioned, since it isn't a DD, go with duals.
My car is a weekend warrior and I switched from a Y-pipe to duals, it's a big difference in quality of sound. It doesn't get annoying to me, I always turn down the radio to listen to my exhaust
And as far as the emissions thing, that is your call....
Old 01-26-2015, 03:58 PM
bad_408_vert's Avatar
I recommend doing something like this.
True duals that go over the axle into a super quiet muffler so that its not on beast mode all the time.
Put 2 cutouts before the axle so that when the cutouts are open, its like have true duals dumped.
For visual Inspections you can get simulated cats, and you can get a good tune to take care of any check engine lights or codes that usually get tripped in absence of rear 02 sensors & cats.
Old 01-26-2015, 10:45 PM
99Bluz28's Avatar
If you can live with the ground clear lose then go true duals. Otherwise stick with "option 1" !
Old 01-27-2015, 12:59 PM
farmington's Avatar
what about true duals with cats in the front pipes? It will quiet it down quite a bit and should still pass a sniffer test
Quick Reply: Stock C/B vs True duals
