5.3 supercharge build heads?
I'm aiming for 500hp for an end result on 93 octane. I've read that the 317 and 243 (799) will lower my compression. But milling the heads can put me in a safe place to run decent boost, with better flow that stock heads (706?)
What's a good target compression ratio to run boost safely?
What size injector should I run with my target hp goal?
I will be doing a ls6 intake swap for clearance reasons.
Any help is appreciated!
No need to change the heads for what you want out of this. I would recommend pulling the heads replacing the gaskets with MLS, some good dual valve springs with hardened push rods, and ARP head studs. 60# injectors will get you to the 700-750 hp mark on pump gas.
Oil pan, you'll want to make sure you get a F-body pick up tube, O ring and windage tray. My O ring is blue, there is red, green, and black also. One tip I've learned the hard way is to take some red Hi-temp RTV silicone and put some on the 4 corners where the rear main cover and timing cover come in to contact with the pan.
