Either my Air fuel gauges are broken or....
my car is running super rich. Last night I ran the wires for my air fuel gauges, and tapped into the purple wire on my harness extensions. To see if the gauges worked, I wrapped the wires to the gauge, connected the power and ground, and turned the car on. The gauges pegged all the way lean, and stayed that way. I figured maybe it was because the car was cold. So i removed the gauges. Then this morning I drove around, came home, connected the wires and started the car. Same thing, pegged all the way to rich. Now my car does stink of gas when its idling, but I thought that was because of the cam and not having cats. What should I do?
The gauge's actions are completely random and unpredictable. They are very precise and sensitve and the slightest change in A/F will throw it back and forth. At idle and cruising, the gauge should bounce back and forth. This is due to the PCM trying to maintain a perfect 14.7:1 A/F ratio. If it goes to lean, it adds more fuel, and vice versa. It over-corrects itself which causes it to bounce back and forth. A/F gauges only provide qualitative readings, meaning you cannot get any solid numbers from them. They can only be used to see changes in A/F as a result of mods, engine problems, and other things. After tuning, I know that my gauge, at full throttle, should have two green and one yellow light. If that changes, then I know something is wrong or something has been changed.
Hope this clears it up
yes but its not a light show at idle. All the lights light up, and stay lit. I had it temporarily wired into the car, it was sitting under the hood I didnt play with the throttle at all.
I tapped into the 02 extension I got from thunder racing. I did use wire thicker than the harness wire too, would that affect it? What should I tap into? Thanks for the help guys.
