how much is this gonna cost me
Pulled from a post on YB
Done this for years,, with a little practice you can repair the tube to the point of looking like new...
If you have or know someone with a large chest freezer fill the pipe partially with water and leave it in the freezer.... Water freezes, expands, and pops it out.
Make take a couple of times to get it all the way out but it will push it out almost all the way....
Of course that's assuming one will fit in a chest freezer....
If not the other thing someone else mentioned about capping it off applying air pressure and heating the dent works too....
weld a freeze plug over the collector end of the primary tube, make a tool to bolt to the cyl. head end of the tube with a air hose coupler screw in it,, pressurize the tube {we use 150 psi} and carefully heat the dents with a acetylene torch,, the dent will push out.. If you have an air leak it won`t work ..Don`t localize the hot too much in one spot or the air pressure will blow a hole.
