Anybody know or have tapped the crank threads?
Old Jun 1, 2004 | 08:45 AM
BLKWS6's Avatar
Default Anybody know or have tapped the crank threads?
Well, found out this weekend my crank threads are completely screwed all the way down. Has anybody ever had a machine shop tap them to a size bigger? Or should i just throw a new crank in it?
either way its got to come out.
or should i just save and get a 382 kit
Old Jun 1, 2004 | 09:16 AM
gomer's Avatar
What about getting a big piece of thick all thread and JB welding (or some kind of super steel epoxy) it down into the crank hole.. then using a really big nut to pull the balancer on and keep it secured?? I think as deep as that hole is you could get enough down in there to make it hold. I know that sounds "out there" but I'd try something like that before I pulled the motor.
Old Jun 1, 2004 | 10:10 AM
BLKWS6's Avatar
Well we thought about it but i wasnt sure how good that would hold. Might give it a try before i pull it. Havent got much else to loose anyway.
Old Jun 1, 2004 | 10:12 AM
BLKWS6's Avatar
And we had a M16 stud that went all the way down and used a nut/washer to hold it. That stud just wont tighten back up.
Old Jun 1, 2004 | 11:48 AM
Smoke T/A's Avatar
Put a helicoil in it. I had the same problem and bought a helicoil kit. Lot eaiser than replacing the crank. IMO
Old Jun 1, 2004 | 02:17 PM
BLKWS6's Avatar
Got any idea where i can get a helicoil that big? I thought there was a nut/bolt place online but cant remember the name of it. Master something.
Old Jun 1, 2004 | 03:51 PM
gomer's Avatar
I buy alot of fasteners for work from this place http://www.fastenal.com/web/home.ex
Call them and tell them what you have going on, they can probably suggest something.
Old Jun 1, 2004 | 03:55 PM
1fastWS6's Avatar
McMaster-Carr
