MSD Atomic AirForce LS7 Intakes Now Available!
I'm proud to announce the first batch of Atomic LS7 intake manifolds are shipping to vendors! We have 14 still available that will arrive next week! If you want your name on one give us a call or order online! Then following week another 25 will be available!!
From MSD:
When you’re serious about power for your LS7 engine, call in the AirForce! The all-new MSD Atomic AirForce intake manifold delivers improved airflow and distribution to improve the performance of stock and modified engines.
The unique bell-mouthed runner entrances maximize airflow and minimize shrouding - all while optimizing the available plenum volume for an unobstructed flow path over opposing runners. The polymer molded 2-piece design allows for easy access to the runners for porting.
Atomic AirForce accepts an OEM or 103mm throttle body as well as stock or aftermarket fuel rails including MSD’s Atomic LS EFI system. The intake bolts on and is supplied with new gaskets and hardware for a direct bolt-on package.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Any cathedral port results out yet? I would like to see what one would do for a bolt-on ls6.
In regards to testing on an LS1; it doesn't appear to be the target market for this intake. IDK, why it would be. Other than having adjustable runners in order to fine tune under the curve, the best LS1 intakes already exist. The "Street Warrior" learned that expensive lesson.
