problems after relocating battery to trunk....
Old Jun 1, 2004 | 02:58 PM
Tiago's Avatar
Default problems after relocating battery to trunk....
I relocated the battery to the trunk in my TA and now even though the car starts up and runs fine, radio keeps its memory just as normal. Now when I jump in the car and go start it the gauges flip out just like it when the batt is low/dead and u try to turn it over. But the car does start just fine. The needles flop over and my odometer resets however.... this is tripping me oout..
TIA..
Old Jun 1, 2004 | 03:05 PM
2002z28's Avatar
sounds like your power is surging.
did you run large enough cable?
check your ground?
Old Jun 1, 2004 | 03:48 PM
Mike K.'s Avatar
I did some research on this myself and 1/0 guage seemed to be the only stuff to use.
Old Jun 1, 2004 | 04:39 PM
99ssleeper's Avatar
99s have a problem witht hat. Mine does it once and a while and my battery hasn't been moved. It is also the original battery, however...
Old Jun 1, 2004 | 05:20 PM
Tiago's Avatar
its very strange that teh car starts fine but the gauges act like the batt is low :/
Old Jun 1, 2004 | 07:40 PM
angst911's Avatar
check the grounds.
Old Jun 1, 2004 | 07:44 PM
Ferocity02's Avatar
There may be many reasons to this. Power surging is not one of them. My gauges were doing the same thing and it turned out to be a low battery. Some people have had problems with the gauge cluster not working propery, which is a dealer fix. And third, the connections may not be solid.
Old Jun 1, 2004 | 09:03 PM
angst911's Avatar
I had this sort of issues when a certain sponsor listed to the right forgot to hook up one of the ground wires on the back of my drivers side head...... he tried to do it blind w/ everything already on, and it fell off within 1 month...
Old Jun 1, 2004 | 09:16 PM
Danny2tek's Avatar
I would check the ground
Old Jun 1, 2004 | 10:30 PM
Cursed1's Avatar
vette=lack of penis
I am having the same issues. I am not sure what it is the problem is quite yet. I will write back if I fiqure it out. Where did you ground the battery to? I grounded mine to the seat belt bracket. I am going to check all of my grounds. I am going to make a good quality connection from the chassis and the engine. I am suspecting there is something wrong with my battery too. I hope to get this resolved soon. I am having transmission issues that I am suspecting are related to this also. Any help would be appreciated. Thanks
Old Jun 2, 2004 | 08:18 AM
Tiago's Avatar
Mine is in the spare tire well and I grounded it to the power antenna bracket, there was a suitable hole already there I ground the paaint off and bolted the cable down. Should not be a issue there.... I sswapped batteries yesterday to see if it would help. This morning it did the same thing again.....
Old Jun 2, 2004 | 02:27 PM
Tiago's Avatar
If I turn the car off and restart it shortly after it doesn't act up. But if I let it sit for hrs it will do it again.... WTF...
Old Jun 2, 2004 | 11:38 PM
Cursed1's Avatar
vette=lack of penis
Do you have a good quality chassis to engine ground? I am suspecting this is my problem.
Old Jun 3, 2004 | 07:55 AM
Tiago's Avatar
I didn't alter any of the existing stock stuff. Doesn't the negative batt cable originally ground the engine to the batt/ then on to the chassis? now I have that terminal open (ground) That maybe what the problem is but it just don't make sense why.
Old Jun 3, 2004 | 08:34 AM
Cursed1's Avatar
vette=lack of penis
Well you no longer have a good ground between the chassis and the engine. I am going to use a piece of 2 guage wire between the engine and the frame of the car. I am hoping that will resolve some of my problems. I am also going to replace the battery in the near future. What type of battery do you have in the car?
Old Jun 3, 2004 | 09:30 AM
Tiago's Avatar
I will try to run another ground, who knows
I am running some oreilley's batt right now but I ordered a Optima red top
Old May 20, 2008 | 12:11 PM
4U2NV-SS's Avatar
Whatever happen did you fix your problem? Mine is doing this now that I relocated the battery!!! Please help!!!
Old May 20, 2008 | 01:41 PM
Tiago's Avatar
no... I accepted it as fucked.
my first optima batt that I put in made the problem go away. Then I let it drain one day and it started doing it again, Im now on my 3rd different optima, they all have done it ever since, I let it go...
Old May 23, 2008 | 05:50 PM
4U2NV-SS's Avatar
That sucks! I checked my gounds with a meter and they all show 12.4 volts.
Did anyone upgrade there steel braided strap on there driver side?, I was thinking of doing that.
Or
Do I need to run a 3rd additonal ground from the engine to the frame?
Please help I hate when it resets almost everything!!!!!!!!
Old May 23, 2008 | 07:10 PM
ls2 bait's Avatar
had the same issue. i ended up putting it back up front because i use my trip odometer to check my gas mileage and it was driving me nuts.
