Fast 92 or Fast 102
Old Mar 31, 2015 | 04:34 PM
nathan_troy's Avatar
Default Fast 92 or Fast 102
Hello,
I have a 2000 WS6 w/ SLP lougthmouth II and K&N intake.
I am about to put Kooks long tubes on the car.
Here is my question, what parts do I need with the 102 setup? Nick Williams TB right? What else do I need, for example, do I need performance injectors, different hardware?
If I go with a 92, do I only need a new throttle body? What parts do I need?
I know that I need a tune. I want to install this intake after the CAM goes in right before the tune.
Thanks
Old Mar 31, 2015 | 04:37 PM
HCI2000SS's Avatar
You'll need fuel rails with the 102 but the 92 you can use your stock ones
Old Mar 31, 2015 | 04:47 PM
Okay, so fuel rails...check
What about these valley pan bolts I have been reading about?
Bigger injectors?
Different throttle cable hardware or kit?
Sorry, just trying to get my plan together.
Old Mar 31, 2015 | 04:51 PM
scotty2000ss's Avatar
This thread looked helpful.
https://ls1tech.com/forums/generatio...ll-i-need.html
Old Mar 31, 2015 | 04:53 PM
HCI2000SS's Avatar
Totally understand man.The valley bolts need to be changed with either one. Don't need bigger injectors. You'll need the proper size TB with either intake and the proper hardware should come with it
Old Mar 31, 2015 | 04:57 PM
Originally Posted by scotty2000ss
Thank you, this is exactly what I was looking for.
Old Mar 31, 2015 | 04:58 PM
Thanks,
I think I will go with the 92 unless their is just some crazy reason why the 102 is best.
Old Mar 31, 2015 | 05:00 PM
HCI2000SS's Avatar
The 102 will make about 5-7 hp more than the 92, otherwise that's really it
Old Mar 31, 2015 | 05:20 PM
I'd wait for the MSD intake results
Old Mar 31, 2015 | 06:55 PM
Pharcyde50's Avatar
For a 102 gonna need rails and possibly a new water pump i switched to a ls2 for clearance and still had to grind it a little bit. Also will have to change the steam line setup to an ls6 or there a few other after market options. Stock throttle cable and bracket will work. The manifold will come with the low profile bolts. I'd get a ported 102 from Vengeance.
