Question re: D585 coils vs. Brackets/Harnesses
Old Apr 9, 2015 | 10:53 AM
Mercier's Avatar
Default Question re: D585 coils vs. Brackets/Harnesses
Hi guys,
In the market for some better coils to ease my paranoia. Some high-RPM stuttering going on when engine compartment is heat-soaked.
Question is, do the D585 coils share the same mounting holes and electrical plugs as the standard/old/whatever truck coils? I'd like to just buy a set of 8 new coils and use my brackets and wiring since I have a few sets of that already.
Thanks ahead of time for your time to help me out.
Old Apr 10, 2015 | 03:08 AM
Mercier's Avatar
Nobody? Seemed like such a simple question I felt silly asking. Maybe I am still silly for asking but still need an answer.
Old Apr 10, 2015 | 07:11 AM
deezee302's Avatar
Il try to help you out as im dealing with coils on my car now as well. The d585 coils have the mounting holes on the sides of the coil, vs the other style of coils that have the mounting holes on the top and bottom.
Old Apr 10, 2015 | 08:30 AM
thunderstruck507's Avatar
it's my understanding you will need coils, coil harness, and a coil bracket and the brackets
you can get all of this as a set from the classifieds for around $100
I would suspect fuel issues before coil issues, the GM coils are extremely reliable
Old Apr 10, 2015 | 08:53 AM
Mercier's Avatar
Thank you, gentlemen. Should I interpret this as "D585 coils use a specific bracket?" Or do they use the same bracket and connector as the other truck coils? I have all truck sets right now.
You are right that it isn't a coil problem. Finally caught it acting up while logging and knock retard is coming in right then. Haven't gotten to the point of tuning the knock sensors yet..LS1 sensors in side of LS2 block. Guess it's time to eat that can of worms.
But I still eventually want the coils that all the cool kids have so want to verify if they have a truly unique bracket/harness or if truck setups share.
Thank you again for your time.
Old Apr 10, 2015 | 09:00 AM
Let me know how that tuning goes because I am about to swap an ls2 into mine and will be opening that same can of worms.
The brackets are specific to the d585 coils. I already use the square type coils on mine (I think they look better and I got them for $40).
Old Apr 10, 2015 | 11:57 AM
Mercier's Avatar
Yes sir. Will do. Hopefully just a matter of modifying the sensitivity/gain/whatever. Thanks for the info.
Old Apr 10, 2015 | 01:29 PM
cmac06's Avatar
Answered already, lol
Last edited by cmac06; Apr 10, 2015 at 01:30 PM. Reason: Question already answered.
Old Apr 10, 2015 | 03:16 PM
miami993c297's Avatar
AC Delco D-585 assembly
AC Delco D-585 Coil
AC Delco D-585 Connectors
AC Delco D-585 Harness 1
AC Delco D-585 Harness 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 1
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 3
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 4
Those parts plus shipping was $593.86.
12-11-2013 D-585 Mounted 1
12-11-2013 D-585 Mounted 2
12-11-2013 Firecore50 custom 1
12-11-2013 Firecore50 custom 2
12-11-2013 Firecore50 custom 3
12-11-2013 Firecore50 custom 4
Old Apr 10, 2015 | 06:09 PM
gagliano7's Avatar
You need the specific brackets that go with the d585 coils. The other truck coils have different brackets for there bolt pattern. The wiring harness are the same.
Old Apr 10, 2015 | 06:49 PM
Mercier's Avatar
Thanks for the visuals!
