front exit exhaust without a turbo?
Old Apr 12, 2015 | 02:46 PM
SUPERIORMOTORSPORTS's Avatar
Default front exit exhaust without a turbo?
I'm thinking about doing front exit exhaust. But I don't have a turbo. I need the back pressure though.Its a track only car. Just for bracket racing. Like it or hate it fender exit doesn't kick up dust and dirty up the car at some po-dunk race track that's dusty. And ground clearance. Just not sure about sound and performance.? Any thoughts?
Old Apr 12, 2015 | 06:47 PM
93NotchLX's Avatar
http://www.yellowbullet.com/forum/sh...d.php?t=427535
Old Apr 12, 2015 | 09:24 PM
Thanks. But that link doesn't really get into ls1 applications or what's needed for decent performance.
Old Apr 12, 2015 | 10:49 PM
LLLosingit's Avatar
Why do you think you need the back pressure on a track only car? Depending on your cars power range it will likely make little difference and may even hurt performance. What's your setup?
Old Apr 12, 2015 | 10:56 PM
LLLosingit's Avatar
You could also run oval exhaust out the side if ground clearance is an issue. http://www.spintechmufflers.com/oval...ng/cat_41.html
Old Apr 13, 2015 | 02:51 PM
Stock bottom end. Ls6 intake. Stock 243 heads. 525lift cam 228duration. Powerglide w/ transbreak. 4.30 gear. 3200 stall. In a 2600lb g body. And I was concerned about o2 sensor position reading correctly. And sounding like ***
Old Apr 13, 2015 | 04:00 PM
here is a idle clip with long tubes under it. bullet mufflers and dumped in front the axle. https://www.youtube.com/watch?v=5UiK...ature=youtu.be
Old Apr 13, 2015 | 07:05 PM
LLLosingit's Avatar
Oval pipe wouldn't hang down to far or you could run something like this http://www.ebay.com/itm/BOOM-TUBE-EXHAUST-RIGHT-SIDE-EXIT-DUAL-3-5-INLETS-21-5-C-TO-C-68-LONG-ARCA-/121420658450?hash=item1c453c3712&vxp=mtr
I guess I don't see how you're going to get front exit headers to work any better than rear exit without making the pipe look like a slinky under the hood.
Old Apr 15, 2015 | 10:28 AM
high n dry's Avatar
It's a g body! U can run a good exhaust w/o any ground clearance issues!
Old Apr 15, 2015 | 10:44 AM
I've got exhaust under it. It kicks up dust and dirt. Trying to clean up underside of the car.
Old Apr 17, 2015 | 02:58 PM
high n dry's Avatar
Y don't u run the torque tech 3" bhw tails???
