Avoiding broken manifold bolts???
Old Apr 26, 2015 | 12:37 PM
StolenFox's Avatar
Default Avoiding broken manifold bolts???
I understand that broken exhaust manifold bolts are common to LS truck engines. Is there anything that can be done (heating the bolt or head) that will help in preventing them from snapping off?
Thanks!
S.F.
Old Apr 26, 2015 | 03:59 PM
99Bluz28's Avatar
I'd spray them all down really good with some PB Blaster the day before, or at least 8 hours before attempting to loosen them.
Old Apr 26, 2015 | 04:47 PM
GreyFox's Avatar
This is what I do. Usually the night before.
Old Apr 26, 2015 | 06:52 PM
spawne32's Avatar
kearny rust cutter...blows pb blaster out of the water
Old Apr 27, 2015 | 08:33 PM
s7ven's Avatar
Automatic transmission fluid mixed with acetone is the best penetrant I have ever used. Used that with my headers/motor mount change and every bolt came out with ease. Be careful though, it will eat plastic and paint.
Also, like everyone else said, the night before spray all your bolts down. I have also used a propane torch with PB blaster before but I am not sure it actually helped that much.
Old Apr 28, 2015 | 09:09 PM
jimmyblue's Avatar
Moderator
One other useful trick is to tighten (just until the bolt
moves) before trying to back it out. I don't know why
it works, but it does.
Old May 8, 2015 | 07:14 PM
StolenFox's Avatar
Thanks for all the tips fellas, got them out with no trouble!
S.F.
Old May 9, 2015 | 02:33 PM
02blksscmro's Avatar
That's great. I hope I'm that lucky.
Old May 9, 2015 | 02:43 PM
rennat_2006's Avatar
Ive never had one break while removing them. Definetely found alot of them broken off from the heating and cooling cycles from running the engine. I take the heat shields off of the truck manifolds and havent had one bust off yet, havent gotten 100k on them like that though to see if that is a long term prevention though.
