going to buy underdrive pulley.which one?
Most pulleys don't show up on a dyno, some people get a couple hp at most.
I think this is because a dyno in 1:1 gear spins the motor much slower.
I bet you'd see better gains in 1-2-3 gears.
But the pulley proves its worth on the track. Always 1 mph faster on a consistent car.
The march with it's fluid dampening characteristic does what it is designed to do and controls the harmonics of the modded engine.
Harmonic control has to be done at both ends of the motor and that requires a well balanced flywheel/flexplate.
All pulleys with the same underdrive ratio, ie 25% will produce the same gain.
March will also not set false KR which has been plaguing ASP's to the point that they had to redesign it.
If you choose an ASP make sure you get the latest version.
Personally I'm going with March with H/C swap.
i know SLP and i think whisper had this problem.ive never heard about ASP pullies causing KR.
