Scraping with Long Tubes
Old May 7, 2015 | 11:28 AM
mad-hatter's Avatar
Default Scraping with Long Tubes
Question of those who have LT's and lowering springs. My car currently is sitting on Eibach Pro-Kit lowering springs. Curious to know if there is clearance issues between the headers and the ground with lowering springs. I understand scraping when pulling into and out of driveways and crossing gutters to get into parking lots...more worried about every day driving on the road.
Old May 8, 2015 | 06:59 PM
KingJacobo's Avatar
I'm lowered with headers and custom catted 3" true duals. My scraping on speed bumps was so bad I had to use coil springs to raise my front end a bit. Mostly the cats scrape though, rarely the headers. If I had a regular Y pipe setup it wouldn't have been so bad. Just be careful and you should be fine.
Old May 9, 2015 | 04:11 AM
kinglt-1's Avatar
bmr springs here with kooks 1 7/8 and TD's...no scraping good clearance.
Old May 9, 2015 | 09:25 AM
Pharcyde50's Avatar
BMR springs here and a modified set of Speed Engineering headers. No scraping here.
Old May 9, 2015 | 10:01 AM
Majestic9C1's Avatar
Strano springs and BBK setup and no scraping...
only thing that scrapes is the airdam
Old May 11, 2015 | 03:02 AM
VolHawk's Avatar
Stock height with TSP duals. Scrape the tip of the drivers side td occasionally
Old May 11, 2015 | 09:38 AM
itSSlowZ28's Avatar
Another on BMR springs with Speed Engineering headers. Read isolators removed and Phab x-pipe. Made sure I got the x-pipe tucked well and I very rarely scrape it. Never scrape going down the actual road, just on bigger bumps and inclines. Haven't had anything touch the headers themselves
Old May 13, 2015 | 10:44 AM
mad-hatter's Avatar
Cool! Looks like I don't need to go up after all. Will probably still raise it up before doing the LT's and y-pipe. Getting real tired of the sagging *** on my car.
Thanks guys!
Old May 14, 2015 | 09:11 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Thanks guys!
That Eibach pro-kit is probably sagging which is giving your car a lower ride height than you should really have. The pro-kit is known to have problem with sagging as the springs get older and more mileage on them. We end up selling a bunch of our BMR lowering springs to customers who are replacing pro-kits with them so that may be an option for you also. If there is any way we can help you out just let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old May 14, 2015 | 09:37 AM
allmotor1's Avatar
I have some small scratches on my long tubes from a couple speed bumps
