Stainless vs. Coated again!!!
Old Jun 4, 2004 | 08:29 AM
txhorns281's Avatar
Default Stainless vs. Coated again!!!
Ok I've read 100 posts on the differences but now I'm looking for actually #'s and/or experience
To my understanding after doing some research, coated mild steel will run a cooler that stainless w/o coating. Is the mild steel coated enough of a difference in surface heat radiation to justify purchasing it over stainless headers???
Looking into a Supermaxx system, here's the reasons:
1) quality of materials = longevity
2) stainless surface heat transmission > mild steel surface heat transmission
the question i need answered is:
stainless heat radiation > or = coated mild steel heat radiation???
or
is stainless heat radiation mildly worse off but still worth it???
i'll get em if my engine bay won't be mucho hotter than if i just went with a coated mild steel... anyone with actual temp #'s would be my hero! thanks!
Old Jun 4, 2004 | 09:32 AM
1BADFNZ's Avatar
actually I think stainless does a better job of keeping the heat inside the pipes.
Old Jun 4, 2004 | 09:43 AM
txhorns281's Avatar
your opinion or your knowledge????
Old Jun 4, 2004 | 09:45 AM
1BADFNZ's Avatar
well that's what the websites selling the stainless say....
Old Jun 4, 2004 | 09:48 AM
txhorns281's Avatar
I hear ya, but then again I could also read about how a TB Bypass kit will add 5-10 hp
It's already known that stand-still alone, SS keeps heat in better than mild steel. But, when you coat the mild steel, does it then become significantly more protective than the stainless or is it somewhat marginal??? Obviously, you could coat SS and have the top-notch setup, but I don't wanna do that if SS is relatively close to if not better than mild steel coated
Old Jun 4, 2004 | 09:50 AM
1BADFNZ's Avatar
true true LOL but check out www.quicktimeperformance.com and check it out .
I have their headers and love them
Old Jun 4, 2004 | 09:53 AM
txhorns281's Avatar
they are pretty sweet, just not too keen on a non-stainless Y-pipe though... Supermaxx is stainless all the way through for the same $$$
Old Jun 4, 2004 | 10:19 AM
jimmyblue's Avatar
Moderator
Stainless has a much lower heat conduction than
mild steel. But, this is not the dominant term in
heat shedding - it's the surface, exhaust-to-steel
and steel-to-air transfer that matters most. The
coating will cut radiative loss on the outside and
cut the steel-air transfer even further. Coated
stainless would be the best of both. Keeping heat
in benefits the O2s a lot. But for the parts of the
header that can't be seen, maybe some of that
header wrap would make more economic sense
and be more effective. I don't buy into all the
"hot gas flows more HP" stuff but I do see a lot
of people having O2 sensor problems after they
put headers on.
Old Jun 4, 2004 | 11:22 AM
txhorns281's Avatar
Great answer to my inital question
put headers on.
Old Jun 4, 2004 | 12:56 PM
Camaro SS 2002's Avatar
My teperature doesn't run any hotter with stainless steel Kook's LT's, compared to the stock manifolds. If you can afford it, get stainless steel LT's for sure. Stainless steel LT's > Mild steel coated LT's.
Old Jun 4, 2004 | 08:59 PM
1BADFNZ's Avatar
Well the QTP ypipe may not be stainless but the merge collector is the flowmaster merge collector and it's supposed to flow much better than traditional pipes welded together.
Old Jun 4, 2004 | 09:12 PM
WERD. I didn't know this until shortly after I ordered my Kook's LT's and catted Y pipe, but im still happy.
Old Jun 4, 2004 | 09:47 PM
Durien's Avatar
stainless all the way... i used to have the jethot coated.....they rusted within 7 months or so...
i got the QTP stainless HV Headers and the sexy merge collector Y and i couldnt be happier and no my car is not running any hotter
Old Jun 4, 2004 | 11:44 PM
txhorns281's Avatar
the only thing about high flow merge collectors is that you honestly won't see that much of a gain benefit from the cost running on stock internals... you might get up to 5 hp and that's being pretty generous and lucky. The high flow collectors are made more for cars w/ cam setups that need the extra velocity to match their cam specs.
And I think I've posted on you before... you're the guy that "should be" making more power with those mods...
Old Jun 4, 2004 | 11:47 PM
txhorns281's Avatar
So no one has actual proof or data or understanding or knowledge of stainless steel heat radiation vs. coated mild steel heat radiation???
By Brett Foote | 2026-06-04 05:00:17
