Where do all these vacuum ports go?
Old 11-23-2015, 06:33 PM
novablue454's Avatar
Default Where do all these vacuum ports go?
I am working on cleaning up the LS6 I got for my swap, and I am trying to figure out where all these ports on the manifold are supposed to go.
there are 2 here:
One on the other side:
and one on the back:
I know the one on the drivers side goes to the EVAP purge solenoid, am I ok to just cap that off on the manifold?
there are also these 2 coolant lines:
As you can see I installed a steam vent kit, which replaced the lines that went to these, are they OK to leave open as well?
Old 11-23-2015, 09:11 PM
Majestic9C1's Avatar
backside goes to brake booster
left side goes to EVAP
right side they get looped together
throttle body goes to passenger valve cover
you can either run a line through the two ports on the throttle body from the radiator to the steam line or just cap them off and bypass it.
Old 11-24-2015, 10:12 AM
Thanks for the reply. Since I am not planning on running evap, can I just cap that off as well?
Old 11-24-2015, 03:06 PM
yeah you can... but if you do I would run some sort of breather filter on the gas tank
Quick Reply: Where do all these vacuum ports go?
