Obnoxious sound
Old Dec 19, 2015 | 12:57 PM
John Sampson's Avatar
Default Obnoxious sound
Hi Everyone,
I have an 02 Camaro SS that I have been building this year and while I love the performance, I hate the sound, it's too damn loud. I know there is an exhaust thread that is 64 pages long, and I checked the ls1 sounds page, but I thought it might be better to post my setup.
Car is an 02 with an M6. Factory suspension except for a BMR torque arm. Factory front tires (10"), and 11" wide rears.
Mods list:
KN cold air intake
Granatelli MAF
MSD Atomic Intake manifold
Trick Flow heads
Mild Comp Cam
MSD coils
SLP Headers with high flow cats
SLP Loudmouth 2 catback
Some other mods that are probably not relevant
Dyno tuned, making 404 at the wheels
Local shop put a j-pipe on yesterday and really did nothing to quite it down, a little at idle maybe... Will wake the dead when it starts cold, I don't mind loud when I get on it, but it's just over the top with the current exhaust.
Do you guys have any suggestions to tone this thing down? I just ordered some 17" tips with resonators hoping they will help, but I'm wondering about a true dual 3" setup, or open to suggestions...
Thanks in advance for any help
Old Dec 19, 2015 | 01:29 PM
HCI2000SS's Avatar
What exactly is a j-pipe?
Old Dec 19, 2015 | 02:25 PM
A J-pipe is supposed to offset the sound waves that are offensive, without effecting air flow. It's a dead ended pipe that sound can enter and reverb back to cancel out certain sound frequencies. It is also called a Hemholz resonator, and is used to reduce drone.
Old Dec 19, 2015 | 02:32 PM
HCI2000SS's Avatar
Gotcha. I'm surprised it's that loud to you even with the cats on. You could try a resonator in the I - section of the y-pipe
Old Dec 19, 2015 | 02:38 PM
My buddy that helped me build it is on the Dodge driving team, and he thinks the SLP Loudmouth 2 catback isn't made for cars making the horsepower I'm pushing, at least not for the street. I'm ready to cut it out and go another way, but hoping for some direction...
Old Dec 20, 2015 | 06:03 PM
JD_AMG's Avatar
Check youtube for exhaust sounds to see what you like, everyone is different so what is loud to you will be too quiet to someone else.
The loudmouth exhausts are certainly on the loud side of things, check out MagnaFlow or hooker, both are cheap and pretty quiet. Then you can add an electric cutout if you want to be loud.
Old Dec 21, 2015 | 08:17 PM
01SuperSport's Avatar
You have one of the loudest exhausts you can buy. I have a magnaflow exhaust that I loved when I had longtubes. Quiet at idle and regular driving with a nice sound at WOT. Plus it looks REALLY nice being stainless steel.
Old Dec 22, 2015 | 11:27 AM
farmington's Avatar
check into the Hooker blackheart system.
Old Dec 22, 2015 | 02:06 PM
Exidous's Avatar
I would consider a dual 2.5" system without bigger tips. Something like 3" cats into a 3" in X with 2.5" dual out into a pair of resonators on to a pair of 2.5" magnaflow mufflers.
This is exactly what I would run if I were to redo my current setup(3"catback single)
It would sounds REALLY nice and not be crazy loud. My car is loudest at startup flare as well.
That blackheart really does look like a great choice.
Old Dec 22, 2015 | 02:07 PM
srs bzns's Avatar
Swap out the "muffler" on the slp with a Magnaflow or something that actually cut down on the Db.
Google Magna-mouth or Borla-mouth for some examples of what I'm talking about
Old Dec 22, 2015 | 02:45 PM
BudRacing's Avatar
I'm liking the borla-mouth combo. Part # 40085
Old Dec 22, 2015 | 09:47 PM
bad_408_vert's Avatar
Add on magnaflow bullet mufflers
Old Dec 23, 2015 | 07:39 AM
98cherrySS's Avatar
The factory option Dual/Dual exhaust delivers a great tone at a reasonably low volume... and it flows very well. Not the easist kit out there to find but one of the best.
Old Dec 23, 2015 | 08:29 PM
Mongoose350's Avatar
The LM2 sounds decent with stock manifolds but not so much with LT's. Add the cam and I can understand why you aren't happy with it. Change the muffler or the entire exhaust with a better set up is my advice. Also be sure that your y pipe isn't one of those terribly designed types with both banks being positioned so that the exhaust streams ram into each other. If you want a y pipe setup, get something with a nice merge, so that the two streams come togeather side by side. I'd say go true duals if you want my OP, best sound and performance.
