Replacement alternator options
Old Jan 3, 2016 | 09:11 PM
vatechguy3's Avatar
Default Replacement alternator options
Looks like my stock alternator has taken a dump just before 100k miles.
Looking for replacment options. I would prefer not to do the truck upgrade, as i want to continue to use the rear mounting bracket.
Obviously, a slightly higher output would be nice, but fitment and longevity is king.
Thanks
Tony
Old Jan 3, 2016 | 09:27 PM
CamaroWhoopAss's Avatar
Mine went out 2 years ago, and the advance auto reman I put in it has worked great since then.
Old Jan 4, 2016 | 08:38 AM
mikesimpalass's Avatar
I think Remy is one of the better brands of replacement alternators. If you look on Rock auto, you can buy either a new or reman remy. I actually think they supply gm with their new oe alternators, but I'm not sure.
Old Jan 4, 2016 | 09:59 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Powermaster has a selection of higher amp alternators in the CS130D case.
BUT the rectifiers are still pretty small. The larger CS144 case fixes that.
Many have done the upgrade to the larger unit without issues caused by the lack of the rear support-including me.
Old Jan 5, 2016 | 10:05 AM
blackandgold's Avatar
if you don't want to do the truck upgrade I'd say get your stocker rebuilt for higher output.
Old Jan 5, 2016 | 11:23 AM
vatechguy3's Avatar
Has anyone tried these?
Slight bump in output, but i never had a problem with the originial one until it died.
http://www.ebay.com/itm/252230950061
Thanks
Tony
Old Jan 7, 2016 | 12:31 PM
WREK LS1's Avatar
This ^^^^. I am using a truck alt. with absolutely no issues. That rear bracket is redundant and not a good enough excuse to not use the truck alt.
Old Jan 7, 2016 | 12:50 PM
I don't think I've heard of anyone who had an issue caused by no back support. I mean the alternators are designed to work with the truck that has no back support.
Old Jan 8, 2016 | 05:50 AM
vatechguy3's Avatar
But the trucks dont go around a road course or pull 1g on a skid pad.
It might be overkill, but dont want something to come free at the track.
Tony
Old Jan 8, 2016 | 08:22 AM
Tony
The only "racing" concern I would have with the truck unit would be super high > 7500 rpm revving. I can't find a single example of one wiggling loose and failing. AFAIK the LS7 doesn't even use a rear bracket and those things have seen a few tracks. I understand overkill, I mean heck I run a 9" and my only engine mod so far is a lid, but I don't think this is a place where there is any gain. If you have a procharger though that would be a justification to stick stock.
Old Jan 8, 2016 | 09:07 AM
high n dry's Avatar
Not to hack, but what truck alternator you referring to?
Old Jan 8, 2016 | 09:38 AM
I run mine from an '03 Escalade, the 145 amp one, I bought an ACDelco from Amazon. Mine has seen auto-x, and if everything goes to plan it'll see a road course this year as well.
Old Jan 8, 2016 | 12:52 PM
JT2000WS6's Avatar
I just replaced mine with a new Napa unit. It has a lifetime warranty and is easy enough to swap out. So if it dies in a few years I'll take it back for a replacement
Old Jan 12, 2016 | 08:20 AM
vatechguy3's Avatar
What was the amp rating of the unit you used?
Tony
Old Jan 14, 2016 | 06:52 AM
Robert Cantu's Avatar
I used a 200a load boss alternator by Alterstart has been flawless! https://secure.mysuperpageshosting.c...00-a/?mobile=0
Old Jan 14, 2016 | 10:48 AM
Majestic9C1's Avatar
I have a 145A truck unit off an 06 Silverado..
been working fine ever since..
Old Jan 14, 2016 | 11:44 AM
JimMueller's Avatar
I've been using a locally rebuilt CS130D with an ASP 2.75" pulley to get rid of my overcharging problems above 6000RPM. But I don't like having to maintain an idle RPM of over 900RPM to get the idle charging to be at stock levels. I'm considering looking for a Powermaster alternator which will give me the desired stock voltage at idle RPM's but that is good until 18000 alternator shaft RPM. Then keep my current alternator as a spare.
Old Jan 14, 2016 | 04:36 PM
vatechguy3's Avatar
The powermaster units are nice, just pricey.
I am considering getting a junkyard unit to replace mine and then having mine rebuilt locally as a spare.
Tony
Old Jan 23, 2016 | 04:00 PM
ss performance's Avatar
Do the truck alternators use the same plug? Looking at pictures the Camaro has a large plastic piece on it that the trucks don't.
Old Jan 23, 2016 | 04:12 PM
Paul Bell's Avatar
Yes, same plug. It's a plug & play install.
