Fueling Questions for New Build
- LS3 bottom End (GEN IV Block)
- CNC'd 243 Castings (11.4:1 Compression)
- 236/242 .620/.612 112+3 LSA
- FAST 102/102 setup
- Factory 02 Z28 MAF and SLP Lid
I am unsure about injector size and brand. I want to utilize my factory fuel pump for at least a couple months as I am dumping quite a bit of cash into the build. If not possible I will replace it, obviously, But I want to see if I can use it for a bit. We are expecting 480-510 RWHP through a Fresh T-56. What size injectors should I be looking at for this buildup and what brand? I want as much "driveability" as I can get from the injectors. Thanks, and feel free to chime in on if my fuel pump can live for a bit.
Those Bosh units you are using require adapters right? While obviously related to how good the tune is, how do you rate the drivability?
