My FAST 102 install, Holley TB and rails - DYNO NUMBERS ADDED
I'm thinking about port matching mine, but I can't remember the thread I saw a few days ago where someone showed a few pics of the process. I can't decide how I'd mark what needed to be removed.
In case you miss my build thread update, my brake booster hose fit fine. No modification needed.
Also, did you figure out o-rings yet?
I went ahead and bought some 1/2" ID heater hose. My factory booster hose has been cut and spliced together before when it was procharged.
#32
I got the low rpm taper to help with the tuning. The ID of the TB is a hair smaller than the full race version. I'm seeing the Holley for $470ish. And the NW for $380ish. And like I said you can't get the NW in black right now.
I did the the one for sale. I would had bought it if I didn't have a hook up on the Holley. And it's pretty dinged up as well...
#33
I checked WS6 Store this morning, and it looks like they still have the NW 102mm TB in black.
#34
Had to take a fair amount off the rear edge of the water pump, if yours has the bolt athe top of the pump you need to shave it down some but it will fit with the bolt there. It's the bottom lip at the front of the intake that hits the back of the water pump. That and where the bolt is seems to be the only bad spots. I put a heat shield under mine so I took a little more off of it. We just got dad's ready to go on so I know it will fit with the bolt in place just take most of the extra material off there
