The truth about TB spacers
Old Mar 19, 2016 | 11:51 AM
  #41
JD_AMG's Avatar
Originally Posted by big hammer
I would say one of the biggest things is to make sure that the spacer is placed BETWEEN the tb and intake
Most of the stuff had me quietly laughing, this made me lose it...
Hammah you da best
Old Mar 19, 2016 | 01:07 PM
  #42
madmike9396's Avatar
*** I'm confused now. I thought the spacer went in front of the TB
Old Mar 19, 2016 | 01:10 PM
  #43
CamaroWhoopAss's Avatar
But everyone knows the easiest way to mae a car faster is to cut a hole in the floor under the gas pedal so you can push the throttle down farther.
Old Mar 19, 2016 | 03:58 PM
  #44
X-ray's Avatar
Originally Posted by themealonwheels
Good point, not using a washer or an improperly calibrated washer could result in possible blinker fluid boiling, which may allow spark past the spark plugs. Always use the best washers available.
I switched to synthetic blinker fluid for the higher boiling point, my blinkers haven't missed a beat since. Some people say it's a gimmick, but I can feel the difference every time I pull the indicator stalk and my feels never lie.
Old Mar 19, 2016 | 06:29 PM
  #45
Darth_V8r's Avatar
Moderator
no that's the MAF spacer. Easy to get them confused.
Old Mar 19, 2016 | 06:37 PM
  #46
Ahhh thank you for clarification
Old Mar 19, 2016 | 10:32 PM
  #47
Mongoose350's Avatar
Originally Posted by panic
gm's patented bolt pattern
Are you taking a ****?
If you have to ask, then you simply don't know hammer.
Old Mar 20, 2016 | 05:49 PM
  #48
joecar's Avatar
If you don't already know then it's a secret only for those in the "know" (who were born into it).
Old Mar 20, 2016 | 06:09 PM
  #49
usnfenix's Avatar
just make sure you buy a spacer that doesnt interfere with your electric supercharger.
i say your because i assume everyone is already running them, 10/10 first must do mod.
Old Mar 20, 2016 | 10:00 PM
  #50
Darth_V8r's Avatar
Moderator
Originally Posted by usnfenix
just make sure you buy a spacer that doesnt interfere with your electric supercharger. i say your because i assume everyone is already running them, 10/10 first must do mod.
I'd be scared. Run a TB spacer AND an electric supercharger? Hope you got a spare block
Old Mar 25, 2016 | 09:16 AM
  #51
'02 WS6's Avatar
That'll cause too much harmonic swirl. Your LS1 may start blowing George Michael tunes out the exhaust pipe. Best bet is to stick to the spacer with port matched MAF ends and the !wire mod on the MAF itself.
Old Oct 28, 2017 | 09:12 AM
  #52
AnotherWs6's Avatar
In for dyno results.
Old Oct 28, 2017 | 10:01 AM
  #53
wannafbody's Avatar
Despite the joking around, no one has actually commented on what a throttle body spacer actually does...it increases the plenum volume by moving the throttle body. Now, does it increase the volume enough to make any difference? I'm guessing BH never got it dyno'd to see if there was an actual performance gain.
Old Oct 31, 2017 | 05:53 PM
  #54
dreadpirateroberts's Avatar
shhhh, don't struggle. don't ruin the troll. just let it happen man.
Old Oct 31, 2017 | 05:54 PM
  #55
Yeah, what's with this SERIOUS stuff??
Old Oct 31, 2017 | 11:15 PM
  #56
big hammer's Avatar
The TB spacer ended up taking a lifter out of the engine
Old Oct 31, 2017 | 11:27 PM
  #57
Never happen on mine; I use a stealth spacer.....
Old Nov 1, 2017 | 04:22 PM
  #58
consider it a blessing. now you can just get a longer pushrod and shove it in there, and it will act like a solid lifter on that lobe.
Old Nov 1, 2017 | 04:47 PM
  #59
LLave's Avatar
HAH! Great read, so much accurate tech, it makes yer' head spin. A spinnin' like that vortexd supercharged air would have been.
Old Nov 1, 2017 | 08:45 PM
  #60
Launch's Avatar
this thread is funny
