Alternator Problems need 'HELP"!!! PLEASE.
Old May 26, 2016 | 06:35 PM
rotanner's Avatar
Default Alternator Problems need 'HELP"!!! PLEASE.
I have 2000 ws6 with a 4 pin ALT wireing setup. The plus got hot and burned threw the wires. I cant Figure out what wires go where in the plug. I can't find anything on any website or google. Called around and still no answer. On this plug is A,B,C,D the wires are color coded. RED,BLACK,PURPLE,ORANGE,YELLOW. I am stuck an the car wont charge if not in the right place.
Attached Thumbnails Alternator Problems need 'HELP"!!! PLEASE.-wire-alt-1.jpg   Alternator Problems need 'HELP"!!! PLEASE.-wire-alt-2.jpg
Old May 26, 2016 | 07:30 PM
Russ K's Avatar
As per my ALLDATA, there is just a red wire to pin B. The other pins aren't used.
Russ Kemp
Old May 26, 2016 | 07:37 PM
rotanner's Avatar
I have 4 others and they where plugged up red is in B but i got a ground an somemore in an its still not charging. brand new everything battery,Altenator an all tests 100%
Old May 26, 2016 | 09:10 PM
S10xGN's Avatar
There's a wiring sticky somewhere on the board, but it's tough to find. Or you could just Google "2006 ws6 alternator wiring diagram"...
Old May 27, 2016 | 11:10 AM
gMAG's Avatar
as Russ stated, many times you'll get better results using another search engine, as Google, Yahoo, etc.
Old May 27, 2016 | 12:57 PM
WREK LS1's Avatar
The red or "exciter" wire is the only wire that needs to be connected to the alt. I bought a replacement connector from eBay that only had the red wire on it. Connected that to the factory wire from the computer and plugged into alt. and it charges fine. Any other wires in the connector should not be hooked up to anything. Mine is a 98 Z with a truck 145A alt.
