Ai 232cc 243s vs afr 230 heads 408
Building a 408 and I have a chance to get some afr 230s, but I already have some ai 232cc heads, I plan on boosting it with a d1sc (8-12 lbs) is there any sizable advantage to the afr heads? I have a hard time seeing any.
Okay, here's my next question; will you put a N/A cam in to start with to optimize the combo in N/A form, or will you put a boost cam in from the get-go? Reason I ask is because if you're going to run an optimal N/A cam, the cam specs for an optimal setup will look much different based on which heads you run. The AFR heads have such high exhaust flow and exception exhaust ports, so you don't want a cam with a lot of duration and you want the LSA to be in the 113 to 115 range. On the other hand, if you run the AI ported 232cc heads, you'll want a cam with more split and duration, and you can run a tighter LSA.
