Security light came on
Old Jun 9, 2016 | 01:14 AM
jon1234's Avatar
Default Security light came on
alright so the stupid Security light came on after leaving work i "accidentally" gave it too much gas and the car was swinging and after then light came on but the funny thing is my horn started working again because before it didnt make a noise so i guess swinging the car is good
Old Jun 10, 2016 | 12:08 PM
xny1989's Avatar
From my experience, it is the wire from the ignition switch that is unable to "read" the resistor in your ignition key. I had this problem and decided to wire in the correct resistors to the wires in the steering column. While this eliminates eliminates this anti-theft device, the alternatives of taking apart the steering column was less desirable. You'll need an ohmmeter to get this to work.
Old Jun 11, 2016 | 12:27 AM
sawblade99Z's Avatar
Measure the resistance in your key pellet then build a resistor that measures as close to the same as possible. There's lots of info on here about it. Search for vats bypass.
