Last min tips please!?
Old Jun 19, 2004 | 10:20 PM
2001 White Ws6's Avatar
Sorry about the late post. Unbolt the driver's side motor mount and then get a piece of 4x4 or 2x4 and keep if towards the front of the car on the oil pan. Go slow so you want crush the oil pan. I only needed to jack it up just a few inches if even that. Remove the oil filter too. After that it was possible to push it in but it was a very tight fit. Once it's in it's easy to get it on the engine.
Probably too late as i see you already made a post about the shitty ypipe...
Old Jun 19, 2004 | 11:23 PM
99CamaroSS's Avatar
NEVER BUY A QTP Y-PIPE!!! header install ended up being cake..just had to cut about 1/4 inch of stamped metal off the edge of my k-member..and take out my oil filter and drain plug..driver side slid right in....passenger side, just had to remove the most foward heat sheild and it slid right in
Old Jun 20, 2004 | 01:49 PM
rangersix's Avatar
I just installed Flowtechs, Drivers side slid right in after pulling steering shaft. Removed heatshield and starter on passenger side and that side slid in also. Just remember to rebolt heatshield before bolting up header or it'll take 4ever using a 7mm wrench. For $270.00 I was plesantly surprised at the Flowtech going in easily and no clearance problems. I had a Custom "Y" fab'd with Cats. The Passenger side has generous room but the driver side sux. My Driver-side Cat needs to be moved up another inch so it goes back to the Shop this week. (Driveway scrapin'.)
