Heads and Intake or Procharger???
I have no plans of ever putting an iron engine in my car so does this still make sense based on those things?
procharger has a lot of hidden costs too sounds like.
Stock small rod gen 3 engines are good to around ~600whp reliably. The record for highest HP stock LS1 shortblock is over 800whp and he's using a STOCK cam. I'm not sure if he's using the gen 3 or gen 4 rods in that one, as some of the 04 GTO LS1s had better rods.
Long story short, your 500whp goal is easily do-able with a stock cam and boost. Personally, I'm a turbo *****. I would turbocharge my blender if it wasn't electric. Mainly because I'm a cheap *** and fabricate my own kits, so I end up with complete kits for cheap, like the $1800 one on my Nova, or the $800 twin setup on the 4.8 S10 (not counting fuel/tuning).
I've had prochargers before. My big block had an F1 on it. It was obscenely loud, but power was predictable. Nice linear boost increase. A turbo hits much harder in the mid-range. My Nova will break traction with ET Radials and go sideways from a 60 roll.
The choice is literally 3 things. Fitment, preference, cost.
Here is a used D-1SC kit with the SDCE bracket. Bob
If it is an LS6, I would get a $450 custom cam spec'ed by Martin Smallwood on a Cam Motion core. And stick the ~$3500 turbo set-up mentioned earlier on it.
I really like the D1SC ProCharger and really plan to build something specifically for one, but I think piecing together a simple turbo set-up and getting the proper cam for it is closer to what you are looking for.
The reviews on that turbo kit were terrible. People commenting about crap build quality and lengthy waiting periods for anyone to do anything about missing parts or parts that don't work. Also people were talking about how crappy their experience was dealing with the owner.
Doesn't exactly inspire confidence leaving my money over there.
Can Someone comment about how the motor will make power on a procharger vs N/A with a bad a** set of heads and Intake?
With FI I also worry about added maintenance and/or decreased reliability. Can anyone comment on that?
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Also, I have heard (I don't take what I hear as the Gospel but I wanted to ask) that the procharger is also all top end power. How does the Procharger's power band compare if that is so. Would it boost the midrange also?
http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm
Take a look at this link, this engine is an LS2/402 with a FAST 92 intake manifold. The ProCharger certainly picks up the midrange as can be seen on the graph. Thanks. Bob
I have had a Procharged car in the past and the stock piston rings did not like 8 psi for very long. Some have had better luck then others, but I would factor in the cost of a forged short block too if you go FI. Or just sell your LS6 and buy 3-4 5.3 engines.
24 PSI of boost on pump gas and I'm making a LOT more than his 500whp goal. Going on my 2nd year without a single hiccup, and I do NOT take it easy on this car.
I personally heads head/intake a complete waste of money when going forced induction. You can cram as much air in there as you want. 7's have been ran on unported cathedral heads and stock intakes. There are half a dozen cars knocking on 7's with a stock bottom end right now (and one dragster that did it without even pushing it).
Stop trying to spend more money than you have to and either get the Procharger or a turbo setup...
FYI, you can get the truck engines in aluminum. Mine is aluminum.
