Heads and Intake or Procharger???
$5200 for:
- Assembled 227cc C&C Heads
- FAST 102
- TB
- Injectors
- Lifters and Trays
- Fuel rails
Crazy!!!! and a bit discouraging. If I am dropping that much dough, that puts me within an earshot of a supercharger. I would love a turbo but no way in hell am i deleting my AC. Just No. Houston= AC always. They also seem to cost more, and I am not running exhaust out of my front bumper, hood, or fender.
What seems to be the best bang for the buck? I know the LS6 has a 10.5:1 compression but I feel like it would make more power on PSI.
Ideas?
v6 radiator , thick like lt1 but no holes to plug , direct fit for ls1 rad
aster bracket
cbm 8.65 crank pulley
ati balancer
sd tune from the start
make your own fmic kit
get procharger big red bov
2 bar map sensor
second fan on procharger shroud 9" fan
water meth is optional but decide from the start bc that will be another tune cost
60lb injectors
dual fuel pumps
Retains A/C, routes downpipe back to factory cat-back. No A/C delete, no fender exit.
http://www.on3performance.com/shop/1...em-retains-ac/
Add BMR tubular K-member, 78mm turbo, 60 lb injectors, 320 lph fuel pump, turbo blanket, billet oil feed block, scavenge pump, radiator shield, and throw in vacuum distribution block.
You're at $3,597 and it'll top out around 650whp.
Cancel the pump and injectors, use a Walbro 450 pump and deka 80 injectors, you're good for 800whp for an extra $40.
Brute speed has an F-body procharger kit:
http://shop.brutespeed.com/ATI-1GJ21...-02-F-Body.htm
$6,600. Comes with 38 lb injectors (wtf?), fuel pump, and a tuner that will reflash your stock ECU for a bone stock engine + the procharger kit.
Rated at 500+ HP.
Rated at 500+ HP.
Thanks! That price comes down quite a bit if a person calls for a price. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
aster bracket
ati balancer
2 bar map sensor
60lb injectors
dual fuel pumps
Rated at 500+ HP.
Well if the turbo is cheaper, then that is a no brainer! However, how much can I realistically expect to make, reliably, with a LS6 (243's and stock short block)?
I have no plans of ever putting an iron engine in my car so does this still make sense based on those things?
procharger has a lot of hidden costs too sounds like.
Thanks! and I may take you up on that. Just have to figure out what I want before I go calling people.
I don't know about anyone else, but I am not fabbing up anything and to pay someone to is like $10k (I asked lol). If I had the skills, time, and patience I'd do it in a heart beat lol
So with the new cam, and valvetrain added to the ticket, we are probably hovering in the $7k+ range. Why do you feel like there is added value going this route? Not being critical just trying to understand what you are suggesting. Sounds bad ***, but why not do the Heads and intake and keep 2k in the pocket? Just curious.
Personally, I'd just keep your cam and current valve train since you're limited to the stock internals anyways. Now if you change that down the road, and run more boost, then a better speced cam and valve train would be wise investment. Right or wrong, that's just my personal opinion
So new cam, valvesprings, lifters, keep TI retainers, and bolt it up?
Because the added power you're going to get will be well worth the 2k. Or, you could keep the stock cam and heads and just bolt on a Procharger. Doing that will get you to your goal of 550 rwhp. There's just so much more room to grow with a Procharged setup. With a heads/cam/intake setup, you're going to be maxed out unless you go bigger cubic inches or add a power-adder.
Here is a used D-1SC kit with the SDCE bracket. Bob
