Heads and Intake or Procharger???
Old Aug 18, 2016 | 10:12 PM
  #41
wannafbody's Avatar
Why not add truck heads to reduce compression slightly?
Old Aug 19, 2016 | 08:13 AM
  #42
nwilson44's Avatar
They would reduce compression but also reduce flow, right?
Old Aug 19, 2016 | 08:16 AM
  #43
HCI2000SS's Avatar
I run PRC 5.3 heads which are a truck head, and they flow great when worked over, but in stock form they don't flow so great
Old Aug 19, 2016 | 08:26 AM
  #44
nwilson44's Avatar
I dont know guys. Forced induction definitely has the sky as the limit. I'm just not sure if I want the added complexity, weight, added risk of heat soak, and added maintenance of forced induction since I am not trying to reach the sky. I got a quote from Texas speed for those heads and they are the heads on their SBE LS1 record car. I know they are good but at almost $3k it has made me want to look at other avenues before spending that much on just heads. Any other head ideas?
Also for now I think I am going to do larger headers (1-3/4 to 1-7/8), 104 mm Lid, and 100mm MAF just to get the ball rolling.
I haven't ruled out FI but, for me, i'm not sure.
Old Aug 19, 2016 | 08:28 AM
  #45
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You could keep it simple and just add 8 psi of boost to your engine just the way it is, and make more power that you can with a streetable heads and cam package. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 19, 2016 | 09:47 AM
  #46
JoeNova's Avatar
Restricted User
Stock 317 heads flow similar to 243 heads.
Head flow doesn't matter anywhere NEAR as much with forced induction.
Old Aug 19, 2016 | 09:56 AM
  #47
BREWS02WS6's Avatar
$3,000 for what heads? I think any heads that would fit your application are well under $2,000 at Texas Speed.
Old Aug 19, 2016 | 10:57 AM
  #48
nwilson44's Avatar
PRC C&C'd 227cc heads. I think $2799 before options, taxes, delivery
Old Aug 19, 2016 | 11:19 AM
  #49
Rise of the Phoenix's Avatar
For that price, go with some TFS heads.
Old Aug 19, 2016 | 01:15 PM
  #50
nwilson44's Avatar
Correct me if I am wrong but dont PRC's 227cc heads outflow the TFS 220 heads and come with 62cc combustion chambers instead of 64?
Old Aug 19, 2016 | 01:28 PM
  #51
JoeNova's Avatar
Restricted User
Infinite flow doesn't mean infinite horsepower.
At some point, the increased flow numbers will stop helping horsepower and start hurting torque.
You could gain 90% of the power of those PRC 227cc heads with heads that are half the price, and probably have more torque.
Old Aug 19, 2016 | 02:30 PM
  #52
imma_stocker's Avatar
Got a new 104mm lid for sale (in Houston) and a set of used 1-7/8 longtubes ready to remove from my Camaro. PM if interested
Old Aug 19, 2016 | 05:11 PM
  #53
BREWS02WS6's Avatar
My PRC 225s were/are under $2k with all the options. Plenty of options at or under $2k with nearly the same outcome, or possibly better.
Old Aug 19, 2016 | 06:28 PM
  #54
HCI2000SS's Avatar
Man I wouldn't even considering wasting money on different heads at this point. Your current heads and low boost are gonna do just fine
Old Sep 1, 2016 | 08:09 PM
  #55
CBAR02SLP's Avatar
Don't know if I'm too late, but I just went thru this ('02 with the stock LS 6 intake/TB and got 404 RWHP...
If I had to do it over, I would do the Pro Charger, and be done with it!
Second choice, all be it a bit more expensive, would be a 525 HP, LS 3, crate motor and enjoy the rush...my '12 Grand Sport continues to amaze me every time I drive it...
Old Sep 2, 2016 | 07:10 AM
  #56
nwilson44's Avatar
It's not too late for suggestions! I really wanted a LS3 when my motor blew last October. I got my car back running this past may and went with a LS6 and even that was stretching the budget.
With a better job now and things falling in place, I am still not sure I would want to just throw this motor away as it runs very well! It dyno'd at 413 RWHP (burning oil from crap valve seals and Header Leak) but it traps 119 in the 1/4. All that is done to it is a cam, Small SLP lid, Small 1-3/4 headers, and Loudmouth catback. So the motor is still fairly stock. I feel like it has a lot of potential left in the heads and intake. One vendor is pretty confident that a FAST 102 and some C&C'd 227's will have me kissing 480-500rwhp with the same cam.
I am still undecided as I would love boost but just not everything that comes with it. We will see I am still carefully considering.
Old Sep 14, 2016 | 01:24 PM
  #57
alaska_guy's Avatar
Only thing stopping me and more than likely most guys from going with a procharger or turbo is the cost....
I would much rather have a mild street able daily driver with forced induction 500 rwhp than a huge peaky N/A setup at 430-470 rwhp.
I have a small cam setup, I went this route because I decided if I wanted to boost my car I could and not have to change a thing.
Old Sep 17, 2016 | 09:48 AM
  #58
kinglt-1's Avatar
You can make 430-470whp with a 346 NA and have nice flat power curve if you spend the money on quality heads and keep the cam reasonably sized. Most want to go cheap on the heads and throw the biggest cam you can fit and end up with a setup that sucks to drive.
