P/N for 2002 LS1 injector clips
Yeah, I lost one of those. And my local dealer doesn't know the part number. Do they have a separate number for those things?
This is a 2002 Camaro LS1, by the way.
From memory, it wasn't very expensive. Give SDPC a call >>-->
Look around and you will find the clips.I was told by a few vendors that because the rails bolt down that the pressure will hold down the injectors and the clips really are not needed- makes sense to me.
He's talking about the clip on the connector. Not the one that holds the injector in the rail.
Just for next time, you can pop just one side of the clip out, and the connector will usually come off. After you do this, snap the metal clips back into the same position they were before you messed with them. When you go to re-install, just plug them in, the clips will click over their keepers and they will not fall off while you are working on stuff, plus your friend wont kick over the parts bucket you set them in and scatter them all over the place :box:
