Ported MSD Atomic on ls1
Old Aug 15, 2016 | 11:51 AM
Nickww96's Avatar
Default Ported MSD Atomic on ls1
I have the opportunity to buy a very low mile Tony Mamo msd atomic intake for my ls1 but i feel it might be too much for a ls1. My build is a tu1 cam with trick flow heads and long tubes. My question is is this intake too much for what im doing. The intake is rather cheap for what it is.
Old Aug 15, 2016 | 12:30 PM
Rise of the Phoenix's Avatar
No, it's not too much for a heads/cam LS1. Many say a FAST 102 is too much, and I can provide you with many threads that prove otherwise, even one that was done by Vengeance Racing.
Old Aug 15, 2016 | 12:56 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
How cheap is rather cheap?
Old Aug 15, 2016 | 01:12 PM
Nickww96's Avatar
About 900
Old Aug 15, 2016 | 01:34 PM
Can the seller verify it's ported by Tony? That is pretty cheap.
Old Aug 15, 2016 | 01:36 PM
Nickww96's Avatar
It has all the paper work. It is infact done by him. Intake has less that 500 miles on it.
Old Aug 15, 2016 | 02:01 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Then you sir, need to JUMP... NOW... ON IT!!!!!
Old Aug 15, 2016 | 02:05 PM
UNDER PRESSURE MOD
That is a good price on it.
If you have any questions with install, let me know... I'm running a non-ported version as well.
Old Aug 15, 2016 | 02:26 PM
Nickww96's Avatar
Im more concerned with if it will work well with the build. Its a friend whos selling it so its no big deal if i dont buy it today.
Old Aug 15, 2016 | 02:54 PM
Nickww96's Avatar
Im running a fly by wire throttle setup what can i use for a throttle body for this thing?
Old Aug 15, 2016 | 03:07 PM
Nick Williams or FAST TB would work.
Old Aug 15, 2016 | 03:27 PM
kinglt-1's Avatar
I would stick with a Fast...less headache!
Old Aug 15, 2016 | 03:48 PM
Nickww96's Avatar
Is there one that doesnt cost 500$+?
Old Aug 15, 2016 | 04:45 PM
UNDER PRESSURE MOD
I would think that a factory throttle body from an ls2/3 would work as well.
Old Aug 15, 2016 | 05:49 PM
Mike Morris's Avatar
Tough call. I am not sure if a ported MSD intake would be better than a out of the box Fast 102 car with that cam. Tony says if you rev it the MSD is the one to go with
Old Aug 15, 2016 | 07:28 PM
Nickww96's Avatar
Would a ls7 throttle body work?
Old Aug 15, 2016 | 07:36 PM
Nickww96's Avatar
Well im certainly not going to baby it but im not going to be shifting at redline all the time. The car will be raced drag strip or autocross and street driven whatever I feel like doing.
Old Aug 16, 2016 | 05:19 AM
Darth_V8r's Avatar
Moderator
I would call tony up and just ask him based on your intended rpm range which is better.
There's a crossover point where the MSD makes more sense but it's higher in the RPM band. The fast still makes better midrange. The MSD looks like it shifts peak power up a little and carries better past peak.
Old Aug 16, 2016 | 07:17 AM
I'm sure there are some other brands out there that cost less, but I don't know anything about them. I'm not very familiar with drive by wire TB's. I know there are alternative options for drive by cable TB's. You can check out WARR Performance and see if they have one. I know they have drive by cable TB's, and it seems they work really well.
Old Aug 16, 2016 | 09:36 AM
big hammer's Avatar
I'd do it. And rev that bitch out
