LS6 valley cover or Catch Can
Old Aug 17, 2016 | 09:00 AM
klinznilk's Avatar
Default LS6 valley cover or Catch Can
Can anyone tell me if it is better to run one version vs the other?
Currently have a 2002 WS6 that is getting heads/cam/intake done which will include a FAST 92 setup and was wondering if i should address the PCV system while im tearing down. Was going to purchase a mighty mouse can but was debating just changing the valley cover to a ls6 style (built in)
Any advise / recommendation would be appreciated as definitely do not want to work on this intake area more than once
Old Aug 17, 2016 | 10:50 AM
bbond105's Avatar
Do both. The LS6 valley cover will let you remove a lot of hoses on your engine and will make it look a lot better.
Old Aug 17, 2016 | 12:01 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Both, without question.
Old Aug 18, 2016 | 12:54 AM
klinznilk's Avatar
Thanks guys!
Old Aug 18, 2016 | 02:32 PM
BREWS02WS6's Avatar
Agree. I did only the LS6 valley cover and have discovered oil mist in the FAST, so now I'm getting a catch can.
Old Aug 19, 2016 | 01:15 AM
bigsticksupra's Avatar
if your car had an oil consumption issue before the LS6 valley cover will take care of most of it. i have both but probably didnt really need the catch can as it doesn't catch much and my IM is dry.
Old Aug 20, 2016 | 08:16 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Yes, do both, especially if your engine has miles on it. My home-grown catch in my 250K+ miles truck can gets this much at every oil change-and I also have the LS6 PCV setup. My intake is bone dry.
Old Aug 22, 2016 | 01:55 AM
klinznilk's Avatar
Awesome thanks guys/gals.
Car only has 68K or so
Old Aug 22, 2016 | 07:20 AM
IDriveChevy's Avatar
Yep I run both to be safe, a few bucks to curb oil consumption is worth it.
Old Aug 23, 2016 | 09:39 AM
Redbull87's Avatar
I thought about doing this on my lq4 since I have a turbo but wondering on the gen 3 lq4 would I need to modify the block like ls1s would need to grind the block?
Old Aug 23, 2016 | 09:49 AM
Paul Bell's Avatar
Only the LS1 blocks needed the grinding mod.
Old Aug 23, 2016 | 10:34 PM
juniorssrollin's Avatar
Yep, do both!
Old Aug 24, 2016 | 12:34 AM
AiDRocks's Avatar
Thanks folks! Got another thing to added to the parts cart. LOL
Old Aug 24, 2016 | 11:21 AM
blackbyrd's Avatar
Originally Posted by Paul Bell
Only the LS1/6 blocks needed the grinding mod.
I thought all the iron blocks had to be modified to use the ls6 pcv breather port?
Old Aug 25, 2016 | 07:47 AM
Paul Bell's Avatar
Even the aluminum LM4 block in my truck did NOT need to have the lump removed to clear the LS6 plate. It's only the LS1 blocks.
Old Aug 25, 2016 | 08:18 AM
blackbyrd's Avatar
thats great news for me, as that was kind of holding me back from that mod
Old Aug 25, 2016 | 04:01 PM
King23's Avatar
I have a 2000 lq4 and it didn't need to be modified so you should be good.
Old Aug 26, 2016 | 08:16 AM
Paul Bell's Avatar
I had to correct myself-why would the LS6 block need to have the lump removed to accommodate the LS6 valley plate??
It's just the LS1 block.
Old Aug 26, 2016 | 09:40 AM
blackbyrd's Avatar
^ i didn't even catch that haha.
I have breathers on both of my valve covers and everything else is capped off, but I have thought about adding the ls6 valley cover, though I have never really had any issues with consumption that I am aware of. I still think it wouldnt be bad with my setup.
Old Aug 26, 2016 | 11:35 AM
usnfenix's Avatar
I ordered one and will do it during my intake manifold swap, might as well its only a few extra steps while your in there.
