Moving ahead with the new ride
--Alan
--Alan
depending on your mods there are other things that can be done that would provide noticeable gains and be far less intense. SSRA (less expensive) or FAST 102 ( more expensive) for example, but hard to know without knowing what you have already done.
--Alan
I know that the car wont lose anything with the 1 7/8" headers and the TDs, and if I'm going to replace headers I might as well upgrade. I'm big on adjustable suspension and TDs were the way to go on my old '95 so I figured Id use the WMC TA, which I know works well and is designed for the TDs. The goal here is to run the same ETs and speed without switching to skinny fronts. I think I'll pick up a bit of power with the headers/exhaust and the TA will help the 60'.. Either way it lays the foundation to upgrade other areas of the car if I want to. The next big purchase will be a 12 bolt with 3.90s..N/A builds with 26" tires love 3.73s to 3.90s... Going to try 3.90s on this build. My old car ran 4.10s but with a 28" tire. The nice part is all the parts will be $1200 and weekend in my friends shop. I remember paying almost that years ago for my stepped 1 7/8" Kooks fir my LT1..
--Alan
Next big upgrade will be a Strange 12 bolt with a spool and 3.90s.
--Alan
--Alan
My initial impressions of the TSP 1 7/8" stainless headers are fantastic. Fit is better than the Pacesetter 1 3/4" they replaced. We had the car on a lift so the install was more of a breeze than on jack stands. We ended up dropping the trans cross member to lower the rear of the motor a hair to help slide the driver's side header into place. The passenger's side almost installed itself. Unbolting and sliding the coil packs out of the way made top side access easy too. We used factory GM manifold gaskets and Totally Stainless locking header bolts. The Totally Stainless locking bolts were worth every bit of the $65. They use ARP bolts and a proprietary pair of locking washers which lock together as you tighten them up and won't loosen. Way easier than fooling with the Stage 8 stuff I've used before. The only slight mod was trimming about an 1/8" off the driver's side K-member ear to prevent a primary tube rub. This is probably not needed if you install poly motor mounts, which I meant to do but forgot to order. Getting old sucks...
The TSP Rumbler X true duals were a breeze to fit under the car. Its a nice exhaust especially for $409. It tucked up nicely and we secured the hangers onto the car with threaded inserts which are basically threaded rivets. This avoids having to pull the back seats to add a nut to hanger bolts inside the car, and makes for a very clean and easy install.
Tying it all together is the MWC TA designed specifically for the TSP true duals. Its a very nice piece and install was easy. I did buy a set of longer TA bolts for the rear from UMI at Carlisle last week and that was a good idea as the mounting flanges for the MWC TA are obviously much thicker than the stock stamped steel TA. We set the pinion angle at -2 degrees for starters.
Also while we were there we replaced the iridium plugs of which a few had very worn (gone) electrodes with NGK TR55s gapped at .050"...
The car sounds sick! On the test ride back home at 10:30 last night I heard a couple little rattles and buzzings from the exhaust which probably just needs a slight tweaking, but that's to be expected as the stainless expands and contracts with the heat cycles. Overall I'm extremely happy. Its rare that everything fits and works as well as advertised. Kudos to TSP and MWC. And big thanks to Bryan (Pharro Performance) for all your help. I owe you big time. Pics and sound clips to follow this weekend. All in all for a total of $1200 its an impressive package for sure.
--Alan
