which vendor for porting
all prices include .660 springs and titanium retainers
intake/exhaust
TEA 320/260 for 1552.00
AI 305/271 for 1300.00
TMS on ebay has the complete 243 heads for 1200.00 but only flows 306/194
PRC 2.5 at texas speed 316/226 for 1650.00, but what catches my eyes is until the 31st you can get a FREE CAM AND PUSHRODS
Engine will be a 408 seeing a 200 shot. mainly street driven. car currently has 1 7/8 dougs headers. kooks catless wye. lm1. 373 gear. t56. slp lid. fast toys ram air
Any advice or suggestions would be helpful. I'm really leaning toward the texas speed package
Stage 2.5 (2.02"/1.57" Stainless Steel Valves)
• LS6/LS2 (243/799)
• TSP .660" Dual Valvespring Kit Featuring PAC Springs w/ Titanium Retainers
• Texas Speed 228R Camshaft: 228/228, .600"/.600", 110, 112 or 114 LSA
• 112 LSA
• 7.350"
• Rollmaster LS1/LS2 Single Roller Timing Set - 1X Cam Gear (p.n. 11-CS1180)
• Texas Speed Ported LS6 Oil Pump (p.n. 25-TSPLS6PortedPump)
The bottom line is there are many good options these days. I would make my decision off of customer service. AI can be hard to get a hold of. TSP and TEA always seem to be a phone call away. Frankenstein has a good rep too. Livernois leaves a bit to be desired far as customer service goes from what I have read as of late. WCCH seems to be pretty good too although you do not hear much about them around here lately. Tony Mamo also produces some solid options, while not cheap, regularly churns out 460-490whp setups on 346's with a 227 range cam. His customer service seems is good too and he is fairly active here. Like I said so many options.
some cnc programs struggle to crank over 410 rwhp...on the other hand the 220 tfs head makes 450 rwhp cake with the correct cam. 1500 bucks max- cnc program by someone you was considering.
1500- 2000 max- go with tfs 220 as cast. I've seen them hurt feelings on the track and the street both. Hard to argue with a head that can put down 450 horse at the tire THREW A STALLED AUTOMATIC with a cam less than 230 duration on the stock bottom end ls1. Seen it over, over and over again. Alot of 10 second cars are running these heads. Also PRC have a as cast 225 head that looks good but have yet to be proven on the track.
2000 bucks and over go ahead and spend 400 more dollars on some cnc tfs/afr heads.
now time to do my short block
