Hesitation and Stumble under load LS1
Old Sep 12, 2016 | 07:38 PM
Snaps's Avatar
Default Hesitation and Stumble under load LS1
So I've had this problem for some time now on my project LS1 swapped Rx7, it stumbles and hesitates under load in 5th and 6th. I can bang through gears 1,2,3,4 like a madman but when I'm puttering on the highway and try to do a slight overtake at 40% throttle I get a stumble, than it sometimes bogs with no power. I also get code p0101, but I've already swapped MAF's and tested with a friends. Also I'm getting all the right signals to the MAF. Next I was going to try and swap out the TPS, but since I'm a mechanic I don't usually just throw parts at cars to fix them. Some more info, I did plugs and wires a bit ago, its cammed with full exhaust. Could I use a retune, or because its not all gears is a sensor fouling?
Thanks!
Old Sep 24, 2016 | 03:52 PM
Snaps's Avatar
Swapped out TPS, still no change. What would make it happen only in 5th and 6th? I read somewhere my AF ratio could be off, possible only at those levels?
Old Sep 25, 2016 | 01:18 AM
tug686spd's Avatar
In my experience a stumble/miss under load at lower rpm's is usually spark related. Since you've already tried plugs n wires maybe swap in your buddies coils ror a test. Qas the dwell messed with at all in the tune?
Old Sep 25, 2016 | 02:33 AM
1970camaroRS's Avatar
p0101 code should put you into SD mode and you're now relying on only the VE tune which SHOULD be slightly rich unless you've made upgrades (head, cam, intake, exhaust, etc.). In that case, now your VE map is going to be lean and provide not enough fuel. Which will cause a hesitation and stumble. You must clear the code to allow the MAF to function again and get out of SD mode. Also, you might want to tune your VE table since I doubt a Rx7 swapped car is going to work with a stock map.
Old Sep 25, 2016 | 08:07 AM
Old Geezer's Avatar
There's a diagnostic/tune forum for this type of t/s. maybe get more responses, there.
Old Nov 8, 2016 | 10:35 PM
hot98z28's Avatar
Default Map
Check out your map sensor.
Old Nov 14, 2016 | 12:07 PM
Hart_Rod's Avatar
Why would this cause a P0101 DTC? TIA
Old Nov 20, 2016 | 04:08 PM
LilJayV10's Avatar
you need to to log it when it's acting up to actually see what it's doing. If not you are just going to be replacing parts until you get lucky.
