PRC 227 Heads?
I was thinking about purchasing these heads after a FAST 102. Winter time or so. but I have some questions....
- What Kind of power can I expect to gain from the 62cc option?
- Do these heads require studs or are bolts okay?
- What head gaskets should I use? I get confused with all the different thinkness available and materials available.
- Will LS7 lifters be okay to replace the stock ones with?
- Again, what can I expect these to do for me? How will the car feel? If im at "417" RWHP from my pessimistic dyno, what gains can I expect?
Really want a nasty H/C set up. Saw something saying how 5.7 LS motors really aren't impressive anymore and are starting to look like how the old pushrod 5.0 looks now..... Can't be having that. I want to make in the upper 400rwhp range. Just want it to be a weapon lol!
If you're at 417 rwhp right now and you add a FAST 102 and the PRC 227cc heads, I'd say you'll end up around the 465 to 475 rwhp range.
Just wanting to make 475+ at this level of investment. I will do the intake and injectors first to see where that leaves me. I should probably sell my headers and get at least some 1-7/8's to help get me there.
sell my whole LS6 top end, and subsidize a decent portion of the upgrade, but how much better are these than ported 243's (in terms of just power) I am not sure. I know they have better valve angles and thicker decks, but I am not throwing a 120mm turbo on it and blowing 55 psi of boost so I am not sure how much those thicker decks will help in an all motor set up. The valve angle revision is nice, so PTV is improved. Idk man.
A lot of benefits going to the aftermarket casting if a person is truly trying to build a max effort setup. Smaller chambers for more compression, laid over valves for improved PTV clearance so you can cut the chambers down even more for compression if desired, or a larger camshaft. There is lot more to a cylinder head than a peak flow numbers or even a peak HP number generated on a dyno, and in my opinion a ported stock casting doesn't compare to what potential these heads offer when utilized properly.
I think it comes down to budget and being honest with yourself about what you are trying to accomplish. Are you building a racecar/ max effort setup or are you looking to make a little more power where a stock CNC ported casting would be sufficient.
Me too.
There have been multiple max effort setups that have seen a 40 rwhp pick up over stock LS1 heads going to these. The combination of valve angle allowing the larger cams, plus the flow and compression the heads usually make a pretty notable gain over what is stock. Due to these differences they can also work well for a smaller camshaft. With the extra piston to valve clearance one can mill the heads further to pick up more compression if desired.
There is no doubt that there is a lot of value in porting a stock casting, but if someone is looking for the most performance these heads will deliver it.
If someone is not wanting to change the cam or compression then these heads would not be the way to go.
John J
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
John J
When I was doing research for mine, I decided there were too many LS7 lifter failures for me to be comfortable. Many people run them and are fine, but I don't remember seeing many issues with at least a Morel 5315. Spend the extra $100 or whatever and have some peace of mind.
John J
- Can I get close to 11.5:1 with your tsunami cam?
- 40rwhp over LS1 heads, what about LS6 heads?
- Can I realistically expect 475+ with your tsunami, FAST 102, PRC 227's, and supporting bolt ons?
- I can expect gains over ported 243's, correct?
Thanks I have really enjoyed all my products I purchase from you guys.
