TPS keeps messing up?
Last week I had to adjust my tps as it was only reading 0.15 volts at idle (was a new tps so had to elongate the screw holes)
I set it to 0.53 at idle and did the relearn on the PCM. For a day it worked fine -transmission shifted lovely and at the right times and the TCC locked up as it should. The next day without having touched anything the shifts became delayed and the TCC stopped engaging. Checked the tps voltage which was as i left it - 0.53v. Did the relearn again and everything was back to normal.
The problem is that it's doing this every day now - one day it shifts fine after the relearn and then overnight it seemingly goes bad.
Why would this happen?
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
The delayed shifting and lack of TCC isn't really apparent at WOT, more on gentle driving and highway speeds when the TCC should lock. When I finally think its sorted and the car is behaving normally, it all goes wrong again the next time I start it up the next day.
Car is a 2001 Trans Am WS6 by the way.
Would a dodgy quality tps cause the PCM to constantly alter its perceived zero percent voltage?
Is it totally necessary to elongate the holes and set the voltage on a new sensor?
how come they don't come with that facility?
Hope this fixes the fault but if not ill be at a loss as what to do next.
Can't understand why it always performs as expected the first drive after doing the TPS relearn but after that it seems to stop working. :-(
The brand new TPS has broken damn it! The return spring has pinged off inside and is rattling around, the plastic which surrounds the throttle shaft falls out in my hand and when you press it back in the potentiometer output is all over the place. Another new one on order.
If this doesn't fix it then I will be out of ideas.
Hard to believe the AC Delco pro one failed within 3 days
Now no lock up at all.
Relearn procedure done. No SES.
Wish I'd never touched the TPS at all now as it was working fine with the original TPS (original one was giving me 7.5% at idle so transmission went hard into drive which is why I changed it. Since then it's not worked properly)
Also if you have the old tps, try and put it back in the way it was and see what happens. Were you having problems before you changed it?
