Can casting number be seen behind power steering pump?
Im looking at getting a trans am, suposed to have a 6.0 in it. And its a good drive to meet the guy with the car. I just want to make sure its an actual 6.0 and not a 5.3 with 317 heads
It is a iron block but thats all the owner knows.
Documentation of the engine work would be ideal. I had a stroked LS1 block im my last f-body, 6.2l 383 setup. No one would know by simply looking at the engine, cast numbers or anything. Now once I started up the car, and raced someone - than it was obvious my engine was not stock.
Hence the reason for the question
But on a side note, is the casting numbers omc8 is talking about raised, or embosed in the block?
Iv taken playdoe and aluminum foil and pressed it over the numbes on the back of a tbi 350 to see if it was indeed a 350. Worked pretty damn good actually.
