Ls6 manifold or fast 92mm manifold
What cylinder heads?
The LS6 worst weakness is the 78mm TB. The Fast 90/92 will make more hp. Depending on the tuners skill the Fast may not be drive quite as well as the LS6.
The LS6 with a 90mm snout works very well. TPiS can do the mod. Dorman coming LS2 with 92mm TB opening could also be a contender.
This is not really a correct way of thinking about it. There is rarely a HP number line drawn in the sand for which an intake or exhaust are "good for". There are guys making 450+rwhp with the LS6 intake...but that doesn't mean they aren't leaving a lot on the table by doing so.
Even on a stock engine the Fast intake will make more peak power. 8-12rwhp seems to be a good expectation for a bolt on LS1.
Depending on cam and heads and displacement it will make progressively more over the LS6 as the LS6 becomes a more significant airflow obstruction. In some applications this can be 30+ rwhp, more commonly 15-20rwhp is realistic.
Eventually the Fast becomes the restriction and a different style intake comes into play for all out high RPM power (but at the sacrifice of low-mid range torque). Seems in high HP applications the Fast just kind of stalls out around 6,500 rpm and flat lines to redline where a tunnel ram intake can continue to climb.
Now is the cost of a Fast worth the gains on a stock or bolt on car? That's a personal opinion but I would lean towards a cam or heads/cam first. The intake can easily be switched later when it will have a better increase.
Thank you. Ya ima just start off with cam/heads first. Thinking bout 243 heads n ms3 -ms4 cam . Not sure yet
Thanks for your input . . Atm stock heads and stock cam. Was leaning for some 243 head's, maybe ms3- ms4 cam. Not sure yet
Whats a good cam? As in average heads you mean 243 heads?
