Wideband advice request.
Old Dec 27, 2016 | 10:54 AM
wph351's Avatar
Default Wideband advice request.
Hello,
I've been contemplating adding a wideband sensor/Guage to my build before I button up my wiring harness.
I have zero knowledge on these. Mostly wondering which setup displays the most accurate and reliable readings.
Thanks.
Old Dec 28, 2016 | 07:39 AM
01ssreda4's Avatar
Here ya go:
https://www.summitracing.com/parts/atm-3379
Old Dec 28, 2016 | 08:11 AM
JoeNova's Avatar
Restricted User
I'm a big fan of the AEM UEGO.
Old Dec 28, 2016 | 10:58 AM
wph351's Avatar
The aem uego looks good to me
thanks guys for helping out.
Old Dec 28, 2016 | 01:09 PM
pantera_efi's Avatar
Default NTK UEGO Meter
Hi, I have used both the NTK UEGO and the Bosch UEGO.
The NTK will last 2X longer.
I bought my first one in 1984 for use with my ECU, the ONLY way they would sell me this item.
I had the sign a NDA/Use Agreement.
I have used the AFX from NGK, now acquired from bmotorsports.com, the AFX-II @ $259.00.
The PLX is also a very UEGO AMP/Gauge, this will support the 4.2, 4.9, L1H1 and L2H2.
The Innovate is the least expensive, least accurate, (reads 12:1 @ 13:1 AFR), Wide Band Device.
Thus I have used Nernst Cell devices for thirty years, the UEGO location IS affected by pressure.
My ECU-882C "reads" EMAP for correct UEGO/EGO calibration.
Lance
Old Dec 28, 2016 | 01:33 PM
thunderstruck507's Avatar
When properly calibrated my Innovate is as accurate as the wideband the local dyno shop uses for tuning to within ~.15 (my wideband reads 12.8 and the dyno wideband reads 12.7). Never had a chance to compare to another.
I've mistakenly ran the car as lean as 13.8:1 at WOT before (for numerous passes) I have serious doubts that reading was a full point more rich than actual or I surely would have damaged something or at least encountered more severe KR.
Not trying to argue just putting forth my own experience with one particular unit.
Old Dec 28, 2016 | 01:47 PM
wph351's Avatar
The aem uego claims .1 accuracy. Does that seem realistic?
Old Dec 29, 2016 | 07:07 AM
JoeNova's Avatar
Restricted User
I use it for basically everything. The few times I've also used a sniffer on the dyno, I didn't notice any variation.
Old Dec 29, 2016 | 10:30 AM
wph351's Avatar
Variation between the dyno sensor and your sensor?
Old Dec 29, 2016 | 10:56 AM
RidetechJosh's Avatar
My AEM uego has been great for me.
Old Dec 30, 2016 | 07:49 AM
wph351's Avatar
The Aem wide band showed up yesterday. It's a decent looking kit. The gauge housing is made out of a super chincy plastic though. Oh well, as long as it functions well I'll be a happy camper.
Old Dec 30, 2016 | 08:54 PM
Firebirdmuscle's Avatar
I have 2 innovate lc2's. One permanent install in it and the other I made so I could move in and out of different cars for tuning. They both work very well and I have not had any issues. I was recommended innovate from a few others, they also have not had any issues with innovate brand. BUT, I do not have experience with any other brand.
Old Dec 31, 2016 | 06:56 AM
Default UEGO Bench Dyno Testing
OK, to be fair, I will state my test.
MY SF-800 bench dyno, my engine, my exhaust with TWO bungs next to each other, an observed test with another witness, the NGK Sparkplug USA manager's (from Japan) son.
My son also as they went to the same High School.
The Innovate read 12:1, the AFRM read 13:1.
The Innovate was calibrated by their method
What could have been my error ?
The Innovate method is to REMOVE the OEM calibration resistor from the UEGO sensor side harness.
Thus I wonder why Clouse thought this could work better.
Lance
Old Dec 31, 2016 | 05:42 PM
Lance
what innovate did you have? i have not had to do what you are describing for calibration on either unit of mine
Old Jan 3, 2017 | 04:33 PM
Redbull87's Avatar
I just put in an Aem and its seems good to me.
