Help with swap, won't start
Old Jan 5, 2017 | 05:15 PM
LunarNike's Avatar
Default Help with swap, won't start
I need help with lsx 5.3 swap. I did the harness myself and relay/fuse block as instructed on lt1 swap. I have power to all pink wires but I'm not getting power to fuel pump. I've tried starting with starting fluid and still it doesn't start. What could be the problem? I'm using a 6.0 harness and pcm. I got pcm programmed by Brendan at lt1swap.
Old Jan 5, 2017 | 05:32 PM
JoeNova's Avatar
Restricted User
Is the PCM turning on the fuel pump relay?
Old Jan 5, 2017 | 06:39 PM
slogo's Avatar
^^^^If it doesn't start with starting fluid, would the fuel pump relay be the first thing to look at?
I would think checking with proper coil wiring would be a place to check.
Old Jan 5, 2017 | 09:40 PM
LunarNike's Avatar
I have power at coils and proper grounding. What else would I check with coil wiring? How would I check if the PCM is turning on the fuel pump relay?
Old Jan 5, 2017 | 09:55 PM
pdxmotorhead's Avatar
is the theft protection turned off in the ECU?
Old Jan 5, 2017 | 10:44 PM
LunarNike's Avatar
I had the ecu sent to Brendan at lt1swap and had vats removed along with emissions and a basic tune.
Old Jan 6, 2017 | 09:09 AM
JoeNova's Avatar
Restricted User
You should hear it click, or the fuel pump prime. Get someone to turn the key while your head is either near the fuel pump relay or fuel pump. Should be pretty obvious even sitting in the driver's seat.
Old Jan 6, 2017 | 04:52 PM
LunarNike's Avatar
Not getting a click from the relay, anyone have any ideas?
Old Jan 6, 2017 | 11:43 PM
slogo's Avatar
One thing to check would be is to make sure right side coil wire harness is to the
right side coils on right side of the engine.
On one customer made harness, he put the odd side harness on the even side
coils, so the firing order was off.
But if your fuel pump relay is not getting a signal you need to figure that out.
I usually find if you use starting fluid, you will get some sign of life if everything
else is working. But I am far from being an expert. Good Luck
I went back and reread your first post and I guess missed the part that said no power to pump.
Old Jan 7, 2017 | 11:29 AM
LunarNike's Avatar
I've check my coils and they all correspond with the correct firing order placement
Old Jan 9, 2017 | 11:19 AM
LunarNike's Avatar
Any suggestions would be appreciated
Old Jan 9, 2017 | 11:25 AM
SQRBODYLSFREEK's Avatar
Security Relearn?
Old Jan 9, 2017 | 11:48 AM
LunarNike's Avatar
Security relearn? What's that and how would I solve the problem? Thanks for the reply
Old Jan 9, 2017 | 12:36 PM
I had to do it when I got a mail-order tune for my truck.
Attempt to start the truck by turning the key to the Start/Run position. Try to crank the vehicle.
Observe that the vehicle fails to start and the security light is illuminated.
Release key to the ON/RUN position (not the ACC position or OFF)
Allow the vehicle to sit with key in the ON/RUN position for no less than 11 minutes. Security light will turn off after this.
When the light goes off, turn key to OFF position and allow the vehicle to remain in the OFF position for no less than 30 seconds.
Repeat #1-#5 for four cycles or until vehicle starts.
Old Jan 9, 2017 | 02:11 PM
LunarNike's Avatar
Thanks for the reply, I tried and no difference but I saw that one of my bulkhead wires wasn't hooked up to a constant 12v(I have a 86 squarebody chevy) so I hooked it up and bam it ran on starter fluid for a second. But I still have a problem I'm not getting power out of my fuel pump relay. What could cause this? Does the fuel pump relay have constant power output or just for a couple seconds if the engine isn't on?
Old Jan 10, 2017 | 01:47 PM
aruss99's Avatar
the fuel pump will prime for two seconds or so before shutting off if the motor is not cranking or running
