Ported heads
Old Jan 5, 2017 | 08:29 PM
AntCamp1992's Avatar
Default Ported heads
Best way to go with ported heads?? Should i just get 243 heads ported and polished or buy a set of TEA flowtech 215CC. What are the benefits etc
Old Jan 6, 2017 | 06:38 AM
hrlyhnx's Avatar
more info.....your goals, expectations and other mods would help you get this question answered.
Old Jan 6, 2017 | 05:26 PM
redhernandez's Avatar
Need more info to answer that question... budget, goals, etc, just like hrlyhnx said
Old Jan 8, 2017 | 01:09 AM
a4 bolts on . 78k miles 02 ss . gonna buy btr stage 3 cam w 660 dual springs and pusher rods 3600 plus stall. trans cooler . keeping it street because i do drive it often just not on very far destinations. already got stock tb ported and milled. hooker long tubes. tspd true duals dumped.. as far as the 243s i know of some local shops that can port and mill. i just want a good tune. . any recommendations???
Old Jan 8, 2017 | 01:11 AM
[QUOTE=hrlyhnx;19497826]more info.....your goals, expectations and other mods would help you get this question answered.[/QUOT
replied
Old Jan 8, 2017 | 03:06 AM
SCott5's Avatar
If your buying the 243s and then sending them out to get ported look into buying a set of Trickflow 220s as cast heads as I bet the price will come out to about the same, just order the heads with powdered valve guides to run stock rockers
Old Jan 8, 2017 | 10:54 AM
Where to get the 220s?
Old Jan 8, 2017 | 11:32 AM
SCott5's Avatar
Brian Tooley Racing
Old Jan 11, 2017 | 07:13 AM
gagliano7's Avatar
As cast 220 trickflows touched up by Brian Tooley are the best bang for the buck.
https://www.briantooleyracing.com/ls1-fast-as-cast.html
