Speed Engineering True Dual Exhaust Kits!!
#842
Gooze are you at stock ride height? Can you post a pic of a soda can under your MWC double drop if you are? It would be great to see how much clearance folks can expect at stock ride height using the MWC double drop as that looks to clear the SE true duals no problem. I'm guessing 1.5" more than in my pic but it would be good to confirm.
Bummer that the MWC True dual X member with short MWC TA doesn't fit the SE true duals. That x member is definitely better than the double drop for clearance.
#843
Originally Posted by 5.7stroker
He's running a mwc double drop cross member. The same one I had. Basically take this picture and add 1.5 inches of more clearance and that's stock ride height. I'm at a 1.5" drop.
Yea the true duals x member would be right where the duals would go, with the double drop it gives it the perfect pocket to go into
#844
i guess we got a runt of a litter .... had it on in our garage (my son purchased it) and how low the one section hangs is ridiculous, & the over the axle section (yes with the panhard relocation kit installed) just wasn't cutting it/fit way too tight. other parts of the system were hitting or near hitting lots of parts underneath & were horrible rattles waiting to happen. ok sooooo ..... off to exhaust shop number one (decent place good known welder, had an open spot on the same day we called) = could do no better than i did in my garage - they would of had to do some cuts & welds & still were not confident that fitment wasn't a nightmare waiting to happen. ok soooo .... exhaust shop number 2 --- very respected & well known go to guy for years (did my custom 2.5 true dual over axle system, and many exhaust setups for myself & friends over the years)-- he had the whole system installed and in place but had my son & i come look at it to make sure before he even tightened one clamp or made any welds that we could see what were easily problem areas, points that were going to hit/rub/vibrate, & how the low hanging section made no sense, & of course that the clamps & bolts were pretty much junk. we opted for NO & just had him take the system off, paid the man for 90 min labor (he & his partner fiddled with it for nearly 3 & a 1/2), and opted for a custom 2.75" true dual over axle system he will be doing tomorrow, that will fit perfectly from the headers back, & for less than what the SE system cost.
sure many have had great experiences with it, but i just felt it fair to give mine, as i'm sure others will run into problems also. i would say it's well worth the money for the higher priced systems &/or a custom fabbed one from a shop. i had read many great reviews b4 referring the system to my son, but i guess when products are made in china with no QC, it's gonna be a 50/50 hit or miss. not bashing in any way simply giving my personal experience with the SE true dual system.
#847
yea i should've taken some in my garage & at both shops on the lifts. kinda regret it now. will do though once the custom one is finished. i'm gonna chalk at least a good portion of it up to being made in china with no quality control, the dual over the axle part being such a ridiculously tight fit even with the panhard relocation kit, the very low quality clamps & bolts that they expect you to use, & for whatever reason they have the one section hang ridiculously low - seemingly for no good reason.
#848
Fivefive934802zerozero
#849
Does UMI or BMR make a x member that works with the SE true duals or is the MWC double drop the only option?
#850
I wonder if the duals are moved slightly to the passenger side then on the TSP true dual setup to allow them to work with the MWC true duals x member? TSP setup however isn't nice and polished like the SE true duals from what I recall. The new SE true duals with their TA and x member should be a good affordable combo that looks good and performs good. They may be the only company that makes both suspension and exhaust parts to ensure fitment.
I finally got around to installing this system on my 2000 SS. I have TSP 1 7/8" long tube headers. This system bolted right up to the headers. I took my time and spent a day tweaking each section from the front to the rear. One twist in a section of pipe will result in move adjustment in another. This system fits nicely.
I have a UMI tunnel mount torque arm with the flat crossmember. I used the supplied nuts as a spacer for the crossmember and flattened the area on the x-pipe that goes over the crossmember for added clearance. Not very hard to do with a 2.5lb hammer. Didn't flatten the pipe much either.
I used the supplied band clamps and bought grade 8 hardware to torque everything down. The hardware was about $20. I used a ratchet wrench and my jack handle as a cheater pipe. I also used nuts left over from my front bumper support delete on the rear hanger install. They have smaller diameter washers that fit.
No cutting was involved to get this system to fit properly. I placed a 2x4 on my jack and lifted at the x-pipe until it touched the floor board and tightened the main front sections first to tuck it as close as possible.
#853
Anyone fit this kit running the bmr xtreme torque with weld in mount? Looks like there wouldn't be enough room for both pipes unless you rework the safety loop bar possibly.
#856
Any update on the new revised clearance exhaust systems? Are they being inserted in to the current batches yet, or are we still waiting? Plan on getting both SE headers and SE rear exit TDs, was just wondering.
#857
Quote " We did make a revision to our dual exhaust for the F-body applications in order to create a little more ground clearance. I do not have a time frame on when the revision would take effect and be available in stock.
Thanks
Jesse"
That's what i was sent from them yesterday.
Thanks
Jesse"
#858
Thanks
Jesse"
Thanks
Jesse"
