Speed Engineering True Dual Exhaust Kits!!
Old 05-06-2022, 08:47 AM
  #1241
AINT SKEERED's Avatar
My speed engineering exhaust where it goes over axle always slips out even with wider clamps. Then my dual tips turn and look crooked. Once I put my motor back in I'm welding it up. Maybe just tack welds but if it doesn't hold straight I don't want it. I never had drone issues but I also had no lock up converter and it stayed above 2500 at all times cruising.
. New set up will be lock up and if it drones ,borla xr1 mufflers and maybe some bullets closer to the headers will be installed.
Old 05-06-2022, 09:50 AM
  #1242
Bspeck82's Avatar
use 3" lap joint band clamps. Shouldn't come loose
Old 05-07-2022, 12:04 PM
  #1243
did that and still come loose.
Old 05-07-2022, 12:25 PM
  #1244
Received 3,111 Likes on 2,426 Posts
Weld it up. Every OEM exhaust I have seen, except for any flex joints, is welded solid. I put a Walker Dynomax system in my Tahoe, clamped it all together, then went to town where I had it welded up at the muffler shop. Peace of mind....
Old 05-07-2022, 12:29 PM
  #1245
theunderlord's Avatar
Unless you're going with v-bands, welding is the only way to make damn sure they don't wobble apart.
The following users liked this post:
G Atsma (05-07-2022)
Old 06-21-2022, 11:22 AM
  #1246
slarsen47's Avatar
Wow!! Just finished going through this whole thread from start to finish!!
Last couple of posts regarding lose connections, I recall reading way back taking out the "hourglass" spacer in the clamp makes tightening more effective.
Anyway I have the whole system off the car because I swapped the M6 for a 4L60e (yes I know everything wrong with this).
After reading all of the posts I am not convinced about putting the dual 3 inch back on.
Sounds like a Y pipe with manual cutouts is the way to go. Flange the Y pipe at the header's and before the muffler to make transmission removal easy. Y pipe through an straight through open bottle muffler, single 3 inch over Moser 9 inch splitting into two 2.5 pipes with tips. I already have the over the axle section back in stainless from another car.
Then uncap the cutouts when racing.
Sounds like a plan..............??
Old 06-21-2022, 12:12 PM
  #1247
Bspeck82's Avatar
Just buy dual band clamps on amazon...
CattleAc (06-22-2022)
Old 06-21-2022, 03:43 PM
  #1248
5.7stroker's Avatar
The Y pipe with dual electric low profile cutouts is the way to go:
https://ls1tech.com/forums/generatio...e-cutouts.html
Old 09-02-2022, 02:35 PM
  #1249
Bspeck82's Avatar
An update, I cut the outlet pipes on the dumped duals back to just outside the seat buckets. I installed borla XS mufflers with an offset Inlet center out. They fit nicely and I have a fist worth of clearance. For a dumped system, it's very quiet.
Old 09-02-2022, 02:40 PM
  #1250
Bspeck82's Avatar
Old 09-02-2022, 03:37 PM
  #1251
Zigy28's Avatar
So I ended up doing major modifications to my se Tru
e drone system.
4 vibrant ultra quiet resonators vband clamps at the headers. It's tight zero flex and stays where it's put.
Results all drone gone rumble still there and it's quality of life is much improved. Here's where I put them.
Old 09-02-2022, 06:06 PM
  #1252
z28pat's Avatar
Is anyone using this setup on a lowered car?
Old 09-06-2022, 10:31 AM
  #1253
ramairetransam's Avatar
Yeah. Who puts duals on and isn't lowered.
Old 11-30-2022, 01:52 PM
  #1254
Ranzz-ws6's Avatar
I’ve purchased the dual all the way out kit.. I’m hoping my fab 9” rear end wont be an issue. Does anyone run a 9” with this kit???
Old 11-30-2022, 03:16 PM
  #1255
Bspeck82's Avatar
it will be fine. Takes some time to get everything mocked up right. Needs that panhard relocation bar to make room for duals
Pbarby (11-30-2022)
Quick Reply: Speed Engineering True Dual Exhaust Kits!!
