Get rid of belt slippage with a CBM manual tensioner
CBM MOTORSPORTS Camaro/GTO long style and Corvette billet manual belt drive tensioners
Camaro/GTO long style. #CBM-10712.
This tensioner is made to fit the 98-02 LS1 Camaro and 04-06 LS1 and LS2 GTO belt lines. It is CNC cut from a solid block of 6061-T6 aircraft grade aluminum here in the USA. We use these manual style tensioners in high horsepower applications when we cannot allow for belt slippage. They also help to eliminate throwing the belt at high RPM's. All tensioners come with a provision for a 3/8" breaker bar for easy adjust-ability.
Corvette. #CBM-10713.
This tensioner is made to fit the 97-present Corvette style belt line. It is CNC cut from a solid block of 6061-T6 aircraft grade aluminum here in the USA. Have problems stretching the belt? This may be a solution to your problem as it does not allow the belt to constantly relax then pull tight. All tensioners come with a provision for a 3/8" breaker bar for easy adjust-ability.
