Need a bit more power
Old Mar 26, 2017 | 02:18 PM
Sladester2's Avatar
Default Need a bit more power
Ran my car down the 1/8th mile (only thing thats local to me) ran a 7.3 at 93 mph. I want to drop that time a bit. I have a 2000 c5 with a yank ss 4000 stall, btr stage 4 cam, vararam, fast 78( dont think its holding me back), orx, catback, et streets(pulled a 1.58 60ft).
Is there anything you guys can think of that may net me a bit more at the track? Besides a gear change( tough in a c5, intake swap, heads swap or taking weight out? Not sure there is much easy weight to take out of the vette. Thanks!
Thinking about just putting a 100 shot to it and calling it a day.
Old Mar 26, 2017 | 04:00 PM
conan's Avatar
This will wake it up a bit...
http://shop.brutespeed.com/97-04-C5-...stems_c597.htm
Old Mar 26, 2017 | 05:20 PM
Sladester2's Avatar
Haha yeah that would. Not quite the direction I pla on going though. I just didn't know if I'm missing some simple mod that can help a bit.
Old Mar 26, 2017 | 05:46 PM
gsxkid's Avatar
1 7/8 headers and some weight reduction will help for sure. With that cam you could use a larger throttle body as well.if you haven't already having the car dyno tuned would help.
Old Mar 26, 2017 | 05:55 PM
Sladester2's Avatar
Thanks I had it street tuned so it should be good in that department I was thinking a larger or ported throttle body may help some.
Old Mar 26, 2017 | 06:23 PM
conan's Avatar
Do you have headers on the car currently or stock manifolds ? Stock heads ?
Old Mar 26, 2017 | 06:52 PM
Sladester2's Avatar
1 3/4 headers. I do have stock 241 heads.. I was thinking about switching out for 243s.. but not sure if the gain is worth not just saving up and getting some aftermarket heads
Old Mar 26, 2017 | 09:22 PM
gsxkid's Avatar
That size cam could also benefit from 1 7/8 or larger header primary
Old Mar 26, 2017 | 09:25 PM
gsxkid's Avatar
https://www.speed-engineering.com/shop-by-vehicle/1997-04-c5-corvette/exhaust/headers/ls1-ls6-c5-corvette-longtube-headers-1-7-8-race-version-x-pipe-stainless.html
Old Mar 26, 2017 | 09:58 PM
taman86's Avatar
larger intake for sure with that cam. the heads are also choking that cam, even stock 243's will choke it. there are some gains to be had by switching the headers for larger primaries. under drive pulley. when you change the intake or heads get another tune done
Old Mar 27, 2017 | 10:54 AM
Sladester2's Avatar
Thanks everyone I suppose Ill start planning on a fast 102 set up along with some better heads.
Old Mar 27, 2017 | 11:25 AM
thunderstruck507's Avatar
I don't think the intake is holding you back much but I could be wrong. Could always port your 78mm and port your throttle body.
How much faster do you want to go? Nitrous is likely to be your best bang/buck if you want to gain much.
If you keep an eye out you might be able to find an underdrive pulley too for around $120. Mine was worth right at a tenth in the 1/8th back in the day.
Old Mar 27, 2017 | 08:56 PM
Sladester2's Avatar
thank you I was wondering if a pully was worth anything really.. I honestly just want to get down to 7.0. I think the car has 7.2s in it as is.
Old Mar 27, 2017 | 10:30 PM
conan's Avatar
Those 2 with a bump in compression would make for some nice gains.
Old Mar 29, 2017 | 10:13 AM
farmington's Avatar
in your case, a good set of heads will give you the most bang for the buck.
Old Mar 29, 2017 | 11:11 AM
if he wants to stay N/A, some good heads would be good for 40-50rwhp
the budget needed for heads, gaskets, fluids, bolts, etc would be more than enough to put a decent nitrous kit on good for 75-200hp depending how brave he is lol
Old Mar 29, 2017 | 11:38 AM
Ls1Ryan2002's Avatar
The best bang for your buck would be to spray. If you are wanting to stay NA you could do heads.
Old Mar 30, 2017 | 03:54 PM
MonmouthCtyLS7's Avatar
Not sure what auto gear you have but I simply swapped in a a 6spd differential, I think i paid $200 for mine and had it cleaned w/ new seals,etc. You could also unload the 78mm Fast and go bigger (have it ported), get a bigger TB and get a 85mm maf. You would be surprised on what you'll gain w/ a good tune. As for a pulley for what you gain its a pain in the *** unless your changing the cam,etc.
Old Mar 30, 2017 | 05:19 PM
gsxkid's Avatar
I agree . I think there are less expensive ways to pick up the little extra you need than to do heads
Old Mar 31, 2017 | 07:42 AM
Also for the work involved I wouldn't swap the 241's for stock 243's. When the time comes if your trying to stay budget friendly send you 241's (or grab 243's) and send them off to AI, or tea. That have a hell of a cnc program.
